Help! Samsung NP670Z5E-X02HK BIOS
  • rielfreak
    • Jul 2017
    • 23
    • Philippines
    Hello! I need bios dump for NP670Z5E-X02HK please.
    board model: Nike2-15H-QC
    there's another id: BA41-02195A
    thanks in advance
  • rielfreak
    • Jul 2017
    • 23
    • Philippines
    Re: Help! Samsung NP670Z5E-X02HK BIOS
    up
    • rielfreak
      • Jul 2017
      • 23
      • Philippines
      Anyone?
      • mahmoodjavan
        Banned
        • Mar 2018
        • 584
        • iran
        Plz send backup
        • rielfreak
          • Jul 2017
          • 23
          • Philippines
          The owner said that it froze during bios update. but if you want the backup.
          There you go. . .
            • 20318
            Try this one .
            • rielfreak
              • Jul 2017
              • 23
              • Philippines
              Thank you so much for this. I'm flashing it now. Hopefully it works. You rock!
              I tried one for NP880Z5E. It has display on external display but nothing in internal display. Don't want to boot on window's either.
              • rielfreak
                • Jul 2017
                • 23
                • Philippines
                Originally posted by SMDFlea
                Try this one .
                I tried it. Unfortunately it does the same thing with the NP880Z5E.
                • rielfreak
                  • Jul 2017
                  • 23
                  • Philippines
                  Try this one .
                  I have a feeling that the GPU is dead because the previous technician heated it and there is some flux residue. It is running so hot as well. So i tried removing the enable signals going to the GFX_vcore to convert it to UMA but still no internal display. It works on external monitor through VGA but i cant boot operating system on it. (Linux and windows).
                  • Habble7
                    by Habble7
                    Suspected Cause:
                    Troubleshooting Attempts:
                    05-22-2025, 07:28 AM
                  • Vesko356
                    by Vesko356
                    08-11-2023, 03:27 AM
                    09-07-2024, 05:50 AM
                  • TJ65
                    Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
                    by TJ65
                    i made out of two broken Samsung Galaxy Tabpro S one that works partially.
                    The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
                    I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
                    The problem is, that the micom Version doesn't match with the bios version, see picture.
                    How can i update the Micom Version? The Samsung bios update wont work.
                    With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
                    01-09-2025, 01:35 PM
                  • zenius
                    by zenius
                    12-08-2024, 06:13 AM
