i need a bios for this laptop because the laptop has a bios pass
need bios for acer da0zqmmb6f0 rev :f please
Tags: None
Re: need bios for acer da0zqmmb6f0 rev :f please
it wont complete the process sir the attachemnet is disagrement when i used your bios to the boardComment
Maybe need to rename with short word like ZQMM.bin only.
EDIT: You've right, content on post#2 for acer E1-410 and have motherboard ID is EA40_BM, meanwhile your board is Quanta.
Also there're 2 kind mobo ZQM and ZQMB present for acer, i think both are different.Last edited by on/off; 02-07-2019, 11:55 AM.Comment
I dont have any P5.0V_ALW on any connection, why was thah?Comment
OMG.
I knew my english not good. just i want to tell you that file from post#2 not match for you. (already mention on EDIT box)
Francisamd1`s file for acer aspire E1-410 mainboard ID wistron EA40_BM.
Your board Quanta ZQM model E5-411......is it same?
Definitely NOLast edited by on/off; 02-08-2019, 12:30 AM. Reason: Delete post impossible, only we can edit the content.Comment
yes my board is zqm e5-411 seriesComment
Ok, try this bios. If it doesnt work then will try to remove password from your backup.Attached FilesComment
by Wg188I have an Acer veriton Z4660G all in one pc,
Model: Z4660G-I5850H1 (VZ4660G_W)
Need bios dump and schematic would save my life !
to make a long story short I bought this all in one used
with a broken lcd, with the objective of making a custom desktop out of it
,it was working perfectly but unfortunately this motherboard default settings does not show post or bios on external screen, I tried everything and every cable/port/screen also ext gpu or internal i also tried to navigate blindly because I could access bios without seeing...-
by James194ztHi,
My daughter has accidentally managed to kill her Acer gaming desktop it has a blank screen after updating and when you press the power button the fans spin, light comes on and it makes 1 long and 1 short beep and no attempt to boot.
All basic troubleshooting has been done we replaced CPU, GPU and RAM from a working machine and no joy, I also noticed a post on here with the same issue and it was the BIOS. I am pretty sure also because it was doing a BIOS update that stopped it working, she knocked the keyboard out by accident during the update and the screen just went...-
by ebyte64Good day.
I would like to request a bios for the following laptop?
Model: Acer P214-52-58CH
Model No: N19Q7
S/N: NXVLHE0H11204BA27600
SNID: 11201936276
Symptoms: Laptop powers on but no picture on screen.
I have already checked voltages and all is present. I have checked resistance on the coils to see if the chipset or cpu might be shorted. All resistances look normal. I have tried diffrent ram and I have reset the bios. I have also visually inspected the board to see if anything is burnt or if there are any traces of liquid...-
Channel: BIOS Requests ONLY!
09-25-2024, 05:59 AM -
by Vesko356First of all thanks to all of our members who have posted previously all methods posted here.
Operating system and OS version.If...-
by verniumENMy laptop model is EX215-23-R7NG
BIOS chip XM25QU128C
Here is my original bin file, as well as how the BIOS chip looks like
My situation is if I press my laptop power on, fan turns on for the first five seconds and turns off, no display (not even acer), but power indicator is on, and the CPU gets warm, even caught one time if powered on for long (before an hour) the fan turns on again, is it only right that I'm approaching via BIOS?
Before I got into this situation, I was just watching movies, and while turned on, pressed the battery reset button and cleaned...-
- Loading...
