I know that what I m looking for is maybe totally unknown... but I have some 3rd party batteries for Lenovo Ideapad B50 ( B50-30, B50-45, B50-70 ) that are ok, ( I have tested them with special charging machine ) but various machines refuse to charge them. I strongly believe that it is the same "whitelist" issue that happens to various Thinkpad laptops that you have to load a modded EC file to let it charge 3rd party batteries. If anyone has any other solution except for breaking the batteries and changing the original circuit board with the 3rd party one, I would be happy to know.
Lenovo B50 Battery Whitelist Bios Request
by lucaszmn
Summary of BIOS Whitelist Removal Problem
Problem:
Initial Findings:- My current BIOS version is N1KET58W (1.45).
- I have a CH341A programmer and have successfully created two full backups of my BIOS.
- I have the ability to use command-line tools on a Linux machine.
- I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
- I concluded that the
Channel: BIOS Requests ONLY!
08-12-2025, 03:01 PM -
by WahazHello,
I found 3 bios chips on the board, which I read with a bios programmer: two XMC model bios chips and a Winbond model bios chip. Each XMC model bios chip has two partitions named XM25QH128A [3.3V] and XT25F128A [3.3V]. And the Winbond model bios chip has three partitions named W25Q80BL 3.3V, W25Q80xV 3.3V and W25Q80DV 3.3V....-
by grimacelordHello there.
I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
History:
1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
I searched for this error online and discovered...-
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
by xsd611​Hello, this is a BIOS file for the Lenovo X270 laptop, read out through a CH341 programmer. I located error 1802 in the PE32 module. This is a detection for the network card's whitelist. How can I bypass or remove the whitelist check? My skills are limited, and I have tried many times but ended up with a black screen. How can I normally bypass this whitelist check? Please help me edit this BIOS file, thank you. It would be great if you could provide illustrations to guide me. Thank you very much!...
- Loading...
