a1465 emc2924
  • alihomee
    • Dec 2012
    • 1570
    • malaysia
    a1465 emc2924
    need to clr me region becoz notebook runs very slow even cannot load os
  • alihomee
    • Dec 2012
    • 1570
    • malaysia
    Re: a1465 emc2924
    anybody can help
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      Re: a1465 emc2924
      can you please try this... i done clear me
      Im Back... sort of...
      • alihomee
        • Dec 2012
        • 1570
        • malaysia
        Re: a1465 emc2924
        it works perfectly for me thanks so much
        • aqibi_
          820-4924-A MBPr 2015 running slow, possible ME Region?
          by aqibi_
          MBPr 2015 13" Early 2015 820-4924-A
          Running slow, with SMC bypass works fine:
          It has a NVME SSD Crucial P2 (1TB), tried another NVME adapter too.
          - No water indicators tripped
          - Sensors using iStat /HW show sensible values, only airport showing 129 degree (which is common) since we don't have ASD for this year board.
          I have removed and dumped the EFI/BIOS:
          - does cleaning the ME Region make sense?
          Side notes
          1) I do not have the original nor compatible SSD to test with
          2) battery is showing service...
          05-06-2023, 07:44 AM
        • tom3k
          Dell Precision 5540. Need clean ME Region
          by tom3k
          Laptop: Dell Precision 5540
          MB: LA-H331P Rev: 1.0(A00)
          Hi.
          I am looking for a clean ME Region 12.0.95.2489 Corporate H CNP/CMP-H B, A
          After extracting my BIOS in FIT the ME Region size is 7565 KB.
          However the ME Region files I fouud online are 11688 KB in size.
          Can someone help me find he correct clean ME Region?
          Thanks!
          Code:
          ║ Family │ CSE ME ║
          06-28-2025, 12:34 PM
        • Adenitz
          Clean ME region - a bit of theory
          by Adenitz
          Hello laptop repair experts,
          can someone plese, help me understand the significance of cleaning ME region in a BIOS dump file?
          I know that Manegement Engine (ME) data is part of BIOS/UEFI firmware. I know that it contains some HW specific data for the particular laptop.
          What I don't know, why do I need to clean ME region if I try BIOS dump file from another laptop (of course same type and model). I'm not sure if this is only because of the serial number (not sure if that is stored in ME region at all).
          Recently, I had a two cases where laptops (one is Lenovo Idepad...
          10-21-2023, 04:44 AM
        • Caimano
          HP 250 G7 runs slow and battery charge is disabled when adapter is inserted
          by Caimano
          HP 250 G7 with i3 8130U, MB EPK50 LA-G07EP REV 2.0 , PN L65699-601, Windows 10
          Laptop works perfectly when on battery and battery is charged correctly when laptop is off.
          Problem is that when adapter is inserted cpu clock is limited (visible in Task Mgr) and performance drops. Also battery charging is disabled when adapter is used and computer is on. As soon as computer is turned off battery charging starts.
          Tried bios update through Windows from version F38 to F42 . Same problem
          Reinstalled windows same problem.
          I tried 2 different...
          11-07-2022, 03:22 PM
        • konovalec85
          Clear me region Acer VERITON L670G Q45T-AS
          by konovalec85
          Hello
          Can someone help clean the ME region?
          I flashed the BIOS with this file and writes intel me unconfiguration in progress when loading
          I wanted to try to clean the region myself, but I don't know which and where to get a file with a clean region for this motherboard. And what version do I need?
          FITool 10.0.46.1002?
          Chipset * North Bridge – Intel Q45 * South Bridge – Intel ICH10...
          01-12-2025, 05:14 AM
