HP PROBOOK 4445s bios repair
  • salawayon
    • Nov 2012
    • 572
    • philippines
    this one had a no display problem... i attached my backup..
    thanks
  • bachir2004
    • Feb 2015
    • 437
    • maroc
    Re: HP PROBOOK 4445s bios repair
    check this one.
    • salawayon
      • Nov 2012
      • 572
      • philippines
      is this my backup and repaired? i tried one posted bios here and it worked but it doesn't have any infos on bios setup... any tools to edit those infos?
        • 20982
        Try this bios, your DMI (serial etc) is included
        • salawayon
          • Nov 2012
          • 572
          • philippines
          thanks.. but it still had no display issue...
          • salawayon
            • Nov 2012
            • 572
            • philippines
            what version of DMI tool could edit the infos on bios for this model?
              • 20982
              Post the bios that works, the DMI will need copying from the old to working bios.
              • salawayon
                • Nov 2012
                • 572
                • philippines
                https://www.badcaps.net/forum/showth...light=hp+4445s
                the one posted by ala_borbe works...
                  • 20982
                  Try wndmifit ,run it from windows. Any version from 2.0 should be ok
                  https://www.badcaps.net/forum/showthread.php?t=69204
                  • salawayon
                    • Nov 2012
                    • 572
                    • philippines
                    wndmifit works..
                    thanks a lot..
                    • studdy05
                      Bricked HP Probook 450 G7 Bios questions
                      by studdy05
                      Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                      Ive got...
                      07-08-2025, 09:24 PM
                    • DiddiAb
                      BIOS Backup / extract 16MB .bin - Lenovo ThinkBook 13s G3 ACN - 20YA0005GE
                      by DiddiAb
                      Recently I used the official Lenovo bios updater software on my ThinkBook 13s G3 ACN (20YA0005GE). The updating process failed and I got a black screen after powering the device. Of course I did not make an own backup before using the Lenovo bios updater.
                      I bought a CH341A programmer and was able to make a connection to the chip while it is still soldered on board. But I did not realise that the chip was a 16MB size and selected the wrong size (8Mbit / 1 MByte) before reading the content of my chip. So the dump I did before erasing the chip is only 1MByte big. I fear that I lost...
                      03-11-2023, 03:15 AM
                    • the_raz
                      Need (unlocked) bios for HP Probook 450 G3 Notebook
                      by the_raz
                      I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                      Laptop number 1:
                      Model: HP ProBook 450 G3
                      Motherboard part number:...
                      12-17-2024, 03:37 PM
                    • Chris_stand
                      Clevo PD50PNN won't boot after BIOS Backup
                      by Chris_stand
                      i hope to find help her in the forum. It is a littlebit tricky. I searched many Days about disabling IntelME that was may major task. So i have a Clevo PD50PNN motherboard.
                      At first i tried to Backup the BIOS with tools direcly from Windows(normaly i am a Linux user). But no full success because not every part of the bios was readable. So i bought a modified CH341a for a Backup.
                      Backup worked but since the backup the Laptop is not booting anymore. I flashed the newest Version oft the BIOS with success, verfiy everything ok.
                      But the...
                      04-28-2023, 03:08 PM
                    • zenius
                      by zenius
                      12-08-2024, 06:13 AM
