need bios HP 14-am127TX
  • cyngo
    • Jun 2015
    • 219
    • Indonesia
    my laptop has no display and I need bios dump for hp 14-am127TX
    please share,thanks
    here original bios
    • 22286
    Re: need bios HP 14-am127TX
    try this one .
    • cyngo
      • Jun 2015
      • 219
      • Indonesia
      thanks. but there is no change. do you have an original bios dump
      • on/off
        • Oct 2016
        • 333
        • Indonesia
        try this from official
          • 22286
          EDIT: Removed bios, @on/off posted the same official bios i was posting.
          • cyngo
            • Jun 2015
            • 219
            • Indonesia
            the problem is still the same with official bios. I will try to check for other possible damage.
            thanks
            terimakasih
            • cyngo
              • Jun 2015
              • 219
              • Indonesia
              I got a laptop with the same type of HP 14-am125TX, with the same code board. the problem is the same as the HP 14-am127tx as above. the exact problem is that the laptop has no display but the LCD occasionally lights up but nothing at all. I have reballed VGA, bios clearme, flash bios but there are no changes. This seems like a common problem with that type. can anyone help?
              • cyngo
                • Jun 2015
                • 219
                • Indonesia
                problem solved. I got the bios file from the official website and extracted it. conclusion of the problem is in the bios.
                this is the bios file
                • fadhz
                  • Feb 2019
                  • Indonesia
                  bisa bantu sy bro... problem yg sama.. gmn cara reflashnya
                  • oreegaano
                    • Aug 2025
                    • Japan
                    Sorry. What key did you use when doing the recovery? Windows+B or Windows+V
                    • mkdj
                      by mkdj
                      Dear all,
                      10-19-2025, 04:41 AM
                    • kingiii
                      downloaded bios is smaller than the original bios dump
                      by kingiii
                      Can someone help me explain how to fix the original bios when downloaded and exacted bios is much smaller than the original one?
                      Thank you very much
                      06-07-2025, 04:21 PM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • bondminer009
                      Need Bios for Latitude 7650 (No Original / dump bios file)
                      by bondminer009
                      Good Evening,
                      Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                      Thank You
                      Salam,
                      Three
                      11-12-2024, 07:48 AM
                    • adelage
                      Merge ECS Z77-H2 bios cap file with original dump
                      by adelage
                      I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                      03-11-2025, 03:07 AM
