pls Bios HP Probook 450 G5
  • arber1232
    • 376
    • Albania
    #81
    Hp 450 g5 bios
    hi everyone my laptop hp 450 g5 (DA0X8CMB6E0) not display and capslock bliking 5 times ..The laptop is water damage i clean board but now caps lock bliking 5 times and light power stay amber Fan spining fast and cpu not geting hot.... THIS IS OLD BIOS
    • peste
      • 12882
      • ROMANIA
      #82
      Re: Hp 450 g5 bios
      try..
      • mek007
        • Mar 2015
        • 13
        • Zambia
        #83
        Re: pls Bios HP Probook 450 G5
        Have just fixed and hp 450 g5 which had no power and i cleaned out a mosfet which had a short and now the unit is powering up . but now the pc has very slow bios response upto 3min to start booting windows (no post delay) posts display in 3 to 5 seconds but will hold at hp logo for 3min before starting to load windows for about another 30 seconds . once in windows there are no symptoms of any nature until next reboot.
        .i flashed bios with new Me file and no change .
        i tried to boot into windows and update bios and it rebooted and took 45min installing bios but once done same thing.
        entering the bios also takes 3min and navigating take more than a min to processes any key strokes.
        i have tested the same file on other 450 g5 pcs with no problem .
        i tried a different bios chip
        • tbs_
          • Apr 2021
          • Svk
          #84
          Probook 450 G5 BIOS Password
          Hello, could somebody please remove BIOS password from this dump? My original bios chip is completely damaged, I found this bios working, but it is locked. Also, did I need change SN and PN after that with DMI tool, or can it be altered in dump file?
          Thank you in advance
          • peste
            • 12882
            • ROMANIA
            #85
            Re: Probook 450 G5 BIOS Password
            try..
            • tbs_
              • Apr 2021
              • Svk
              #86
              Thank you very much. After writing all IDs and locking MPM working again
              You are true hero. Have a nice day
              • Zoublerh
                • May 2021
                • 5
                • france
                #87
                Hi every one,
                I dont know if it will be possible to fix my problem,
                But unfortunatly i made some mistake trying to flash the bios of my DA0X8CMB6E0 rev e.
                Using for first time eeprom programmer, i didnt choose the right chip on the ch341a software, so at first when i did a backup of original bios in my computer, the bin file was only 64Kb cause of wrong selected chip
                When i realized it it was too late, i had already programmed another bios in the chip, so after some documentation i tryed to flash almost every bios that i found in this thread and google with flashrom, but, no one of them work correctly, only getting 5 blinks on caps lock, black screen, and fan goes high.
                i put in attachment the 64Kb bios that i save, if it may help ?
                If some one solved anything like this, any help would be appreciated.
                Thank you in advance for your answers
                • Zoublerh
                  • May 2021
                  • 5
                  • france
                  #88
                  HP 450 G5 DA0X8CMB6E0 rev e
                  Hi every one,
                  Using for first time eeprom programmer, i didnt choose the right chip on the ch341a software, so at first when i did a backup of original bios in my computer, the bin file was only 64Kb instead of 16Mb cause of wrong selected chip
                  When i realized it it was too late, i had already programmed another bios in the chip, so after some documentation i tryed to flash almost every bios that i found in this forum and google with flashrom, but, no one of them work correctly, only getting 5 blinks on caps lock, black screen, and fan goes high.
                  • peste
                    • 12882
                    • ROMANIA
                    #89
                    Re: HP 450 G5 DA0X8CMB6E0 rev e
                    Originally posted by Zoublerh
                    Hi every one,
                    try..
                    • Zoublerh
                      • May 2021
                      • 5
                      • france
                      #90
                      Hi Peste,
                      Thank's for your answer,
                      Unfortunately i got the same result with the bios you send, black screen, 5 blinks, fan go high.
                      I don't understand why any BIOS work,
                      i tried :
                      - 11.8.50.3425_CON_LP_C_NPDM_PRD_RGN_outimage.bin
                      - 11.8.50.3425_outimage.bin
                      - 11.8.50.3470_CON_LP_C_outimage.bin
                      - DA0X8CMB6E0 REV E OK.bin
                      - HP ProBook 450 G5 _da0x8cmb6e0 reve 4MATIC.bin
                      - HP ProBook 450 G5 DA0X8CMB6E0 REV-E BIOS X8C.bin
                      - Orig+Q85_011101+11.8.50.3425_CON_LP_C_NPDM_PRD_RGN_outimage.bin
                      - Orig+Q85_011200+outimage.bin
                      - Q85_010901
                      - W25Q128.BIN
                      - W25Q128BV@WSON8_20201110_110401 DUMP_11.7.0.3307_CON_LP_C_NPDM_PRD_RGN.bin
                      Is there any reference to some hardware ID or serial number in the bios content ?
                      I didnt find a way to get hp original factory bios in there website.
                      Anyway, thanks for your answer
                      • dihcar84
                        • Aug 2012
                        • 193
                        • morocco
                        #91
                        try this...
                        • Zoublerh
                          • May 2021
                          • 5
                          • france
                          #92
                          Originally posted by dihcar84
                          try this...
                          Hi dihcar84,
                          Got the same result, black screen, fan go high,
                          when i try to boot i only let motherboard with ram, screen and power entry, i removed all other devices (battery, ssd, sd card reader wifi/bluetooth board, speakers, pad, fingerprint sensor) also i removed cmos battery
                          i swap ram
                          is there anything i do wrong ?
                          PS : dihcar84 my parents born in rabat, and got an house in Kenitra ^^
                          • mattom941
                            • Jan 2021
                            • 8
                            • Polska
                            #93
                            Rebuild bios bin HP 450 G5
                            would someone be very nice and help me rebuild the bios file to make sure it is ok?
                            The old owner changed the BIOS on his own and now the laptop does not start.
                            MB: DA0X8CMB6E0 REV:E with integrated nvidia graphs
                            Old BIOS bin in attachment.
                            Thanks good peoples
                            • peste
                              • 12882
                              • ROMANIA
                              #94
                              Re: Rebuild bios bin HP 450 G5
                              Thanks good peoples
                              try..
                              • Kehinde
                                • Feb 2020
                                • 5
                                • Nigeria
                                #95
                                Re: hp 450 g3 unlock
                                Pls help me unlock the password on this bin file
                                • nerazzurri_daft
                                  • May 2021
                                  • Russia
                                  #96
                                  Re: HP probook 450 G5 bios password
                                  Hi. Need help to reset bios pass on my ProBook G5
                                  • peste
                                    • 12882
                                    • ROMANIA
                                    #97
                                    try .. if it works write the DMI information
                                    • binoyroy
                                      • Sep 2017
                                      • 51
                                      • bangladeah
                                      #98
                                      https://www.badcaps.net/forum/member.php?u=201805
                                      please check
                                      • M1HX
                                        • May 2021
                                        • Slovenia
                                        #99
                                        hp probook 450 g5 5 blinks on caps
                                        hello if some1 can help me i have hp probook 450 g5 org bios dump no start nothing i replaced bios from another board and now its starts but 5 blinks on caps and num but after a few seconds it will boot to windows and all is normal I attached both dumps if someone could help me
                                        • peste
                                          • 12882
                                          • ROMANIA
                                          #100
                                          Re: hp probook 450 g5 5 blinks on caps
                                          try..
                                          • studdy05
                                            Bricked HP Probook 450 G7 Bios questions
                                            by studdy05
                                            Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                            Ive got...
                                            07-08-2025, 09:24 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • the_raz
                                            Need (unlocked) bios for HP Probook 450 G3 Notebook
                                            by the_raz
                                            I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                                            Laptop number 1:
                                            Model: HP ProBook 450 G3
                                            Motherboard part number:...
                                            12-17-2024, 03:37 PM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
