pls Bios HP Probook 450 G5
The BIOS is corrupted after an update (3 long beeps/2 short beeps).
Here is the BIOS of the computer.
Thank you in advance!
PS: The motherboard is DA0XCMB6E0 rev:E
Prod id 3GH65ET#ABFAttached FilesComment
5CD85172BQAttached Files↵
https://www.badcaps.net/donateComment
HOLA AYUDA Contraseña del BIOS de la HP ProBook 450 G5 he probado otras BIOS y tarda demasiado en encender subo mi BIOS bloqueada
HELLO HELP HP ProBook 450 G5 BIOS password I have tried other BIOS and it takes too long to turn on I upload my locked BIOS
in English please..Comment
post the S/N, the motherboard model, etc.
Every donation made will go towards server fees and maintenance costs.Comment
tried other BIOS and it takes too long to turn on, I upload my BIOS is locked HELLO HELP HP ProBook 450 G5 BIOS password I have tried other BIOS and it takes too long to turn on, I upload my BIOS is locked
HP Probook 450 G5
MDEL RTL8821CE
P/D DA0XCMB6E0 rev:E
S/N 5CD8085GKV
need both fileHELLO HELP HP ProBook 450 G5 BIOS password I have
HP Probook 450 G5
MDEL RTL8821CE
S/N 5CD8085GKVComment
hello I have tested nearly 20 models of BIOS files, but in some of them only the orange light flashes and the device does not turn on, and in some other BIOSes, the device turns on but does not show an image and the fan spins fast. The BIOS of this device was already replaced by another repairman. and the original BIOS file is not available for me to upload
Please put a suitable Bios file for this device. Thank you
ProBook 450 G5
CPU: i5 gen7
VGA:onboard (intel)
DA0X8CMB6E0 REV E
ProdID: 4RJ92PA#ABJ
SN# JPH9172TVD
please clear me i have late display problemAttached FilesComment
I have an HP Probook G450 G5 that I deleted the BIOS password a few years ago, reprogrammed it and it works fine. What happened is that what I found on the internet said it was for that model, however when I enter the BIOS it tells me it is an HP Probook g470 G5. The problem I have here is that it takes a long time to turn on (HP logo appears) and most of the time it does not turn off, I have to force it to shut down. Images attached. Can you help me?Comment
RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTINGI have an HP Probook G450 G5 that I deleted the BIOS password a few years ago, reprogrammed it and it works fine. What happened is that what I found on the internet said it was for that model, however when I enter the BIOS it tells me it is an HP Probook g470 G5. The problem I have here is that it takes a long time to turn on (HP logo appears) and most of the time it does not turn off, I have to force it to shut down. Images attached. Can you help me?
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
I have an HP Probook 450 G5 that I deleted the BIOS password a few years ago, reprogrammed it and it works fine. What happened is that what I found on the internet said it was for that model, however when I enter the BIOS it tells me it is an HP Probook 470 G5. The problem I have here is that it takes a long time to turn on (HP logo appears) and most of the time it does not turn off, I have to force it to shut down. Can you help me?
ProdID: 3YGO6UT#ABA
SN: 5CD8381GH1
MOTHERBOARD: DA0X8CMB6E0 REV EComment
hello
i have issue with hp probook 450 g5 DA0X8CMB6E0 REV E
freez hp logo
SN: 5CD904505Q
backupAttached FilesComment
hi try new fileAttached FilesComment
HP ProBook 450 G5 with nVidia Graphics
SN# 5CD9042PNY
Hello seniors, one of my clients Brought me to fix his Laptop. I have fixed the Board, but someone else tried to fix it but failed, and they also changed the BIOS.
Now it's showing the wrong SN #, and not showing the Graphics Card also. I am attaching Its DUMP as its not its own. Kindly someOne make for me .bin with the provided SN# plz.Attached FilesComment
by studdy05Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
Ive got...07-08-2025, 09:24 PM -
by macabookHello everyone,
Channel: BIOS Requests ONLY!
07-24-2025, 02:17 PM -
by piratiHello everyone,
by the_razI'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
Laptop number 1:
Model: HP ProBook 450 G3
Motherboard part number:...-
- Loading...
