BIOS HP Probook 6570b please
  • sopik78
    • Nov 2013
    • 517
    • Czech Republic
    Dear friends, can you please share BIOS dump and schematic for HP Probook 6570b, MB CASPER-DIS-CR-HPB MV_MB_V1.
    BIOS 8MB file.
    Any help will be highly appreciated.
    • 21053
    Re: BIOS and schematic HP Probook 6570b please
    Can you post your bios backup .
    • sopik78
      • Nov 2013
      • 517
      • Czech Republic
      here
        • 21053
        Heres your new bios .
        • sopik78
          • Nov 2013
          • 517
          • Czech Republic
          Thanks SMDFlea, tried but with no luck, still doesnt work.
          Charge light blinking orange/white, no 3 and 5VALW, no charging. Cant see any short, but without schematic..
            • 21053
            Sorry,no schematic. You should check which IC generates P3V3AL (3VALW) on similar schematics,or take note of the QFN IC`s on the board,if you don`t recognise anything by the marking code then search on google e.g. if you see a QFN marked 51123 search for: 51123 IC ,Marking code 51123, IC marked 51123 .Just try different searches.
            • sopik78
              • Nov 2013
              • 517
              • Czech Republic
              Well, this seems to be a bit problem, cause it looks that IC is marked 577BS and I cant find any datasheet. So I have no idea what measurement I should do.
                • 21053
                It could be a switch for 3VS ,look at the other QFN`s
                • sopik78
                  • Nov 2013
                  • 517
                  • Czech Republic
                  Well, strange thing happened. After some experiments with applying +3V on KBC to make sure it is not shorted or damaged system turned on with some error codes on postcard, so flashed to original BIOS and laptop started with artefacts on screen. Reballed GPU and laptop works like a charm again
                  Anyway, thanks for your help!
                  • K3vco
                    • Nov 2018
                    Hey Guys,
                    have someone a clean bios dump?
                    I' ve attached my locked old one.
                    Greetings Kevco
                    • jebadoss29
                      • May 2016
                      • 12
                      • india
                      anyu one pleas help me , i want 16mb bios for hp probook 6570b
                      • rachid1271
                        • Jul 2014
                        • 5
                        • maroc
                        thank you
                        • M1624
                          • Feb 2019
                          • 4
                          • Poland
                          Re: BIOS HP Probook 6570b please
                          Hi i need 16MB bios for HP 6570b W25Q128FV
                          • lapfix
                            • Mar 2020
                            • 2740
                            • my workshop
                            Post your old dump
                            • Vesko356
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              W25Q128FV/
                              ...16MB...
                              W25Q128...?... ..16MB...?
                              HP Probook 6570b with W25Q128FV bios chip and 16MB bios file? Really? Check again laptop model number.
                              https://www.alisaler.com/hp-probook-...b_v1-bios-bin/
                              Become a Badcaps supporter
                              Thanks to all supporters.
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                Yea, it must be the the mobo with discrete ATI graphics, try the bios for EliteBook 8570P, it should be OK:
                                https://drive.google.com/open?id=0B6...mtsYnFkNlVNODA
                                • M1624
                                  • Feb 2019
                                  • 4
                                  • Poland
                                  i have HP 6570B with W25Q128BVFG
                                  • M1624
                                    • Feb 2019
                                    • 4
                                    • Poland
                                    and with intel graphic
                                    • saadraa
                                      • Sep 2015
                                      • 15
                                      • iran
                                      this bios ok full dmi whitout pass
                                      • b tech
                                        • Nov 2019
                                        • 9
                                        • pakistan
                                        Hello everyone!
                                        need Hp probook 6570b bios bin file. 4mb bin file needed
                                        thanks
                                        • studdy05
                                          Bricked HP Probook 450 G7 Bios questions
                                          by studdy05
                                          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
                                          Ive got...
                                          07-08-2025, 09:24 PM
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                          HP ProBook 6570b 6000 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 6570b can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 6570b boardview and 6570b schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ProBook 6570b is accurate,...
                                          09-06-2024, 05:27 AM
                                          HP ProBook 6570b Notebook 6000 Specification for Upgrade or Repair
                                          This specification for the HP ProBook 6570b Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 6570b boardview and 6570b schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ProBook 6570b...
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
