Dell latitude e5440 bios
    VAW30 LA-9832P
    Rev 1.0 (A00)
    Doesn't POST, board ir taking 0.2 amps, fan spins and then board shuts off.
    Best Regards,
    Raitis
    Re: Need BIOS for Dell E5440
    Originally posted by BremiX View Post
    VAW30 LA-9832P
    Rev 1.0 (A00)
    Best Regards,
    Raitis
    here you go.....ok tested.
    • microchipbtl
      microchipbtl commented
      Editing a comment
      Perfect bin thanks lot
    Thanks but didn't fix the issue.
    And tip about those two dumps, they are 1kb larger than chip can hold so you need to delete FFs at the end.
      Hy I am looking for this bios , on board ther is two chip U1 U2 ?
      thanks
        Re: Dell latitude e5440 bios
        here is
        with good chance
            both sources have a slightly larger (1bit) size from the originals
              Try these:
                Perfect now it's working fine Thanks
                  hi, did you find any solution after all? i had the exact same problem. trying flashing both chips but nothing changed.
                    VAW30 LA-9832P
                    Rev 1.0 (A00)
                    Best Regards,
                    Raitis
                    test plz
                      I'm looking firmware U38 MEC5057 KBC
                        thank u so much
                          probleme dell e5440
                          this dell take 20 seconde to show up dell logo how i can fix that
                            Re: probleme dell e5440
                            Try to clear Region ME
                              hox i can do it
                                Originally posted by nabilgo View Post
                                hox i can do it
                                If you`re willing to learn how to do it yourself All info you need is at post #2 https://www.badcaps.net/forum/showth...light=win-raid
                                Use ME Analyzer to check the ME firmware version in your bios dump,then follow the guide at win-raid, or watch youtube videos if you can`t follow the guide.
                                You can also try Intel Easy Clean ME from post #6 https://www.badcaps.net/forum/showth...light=win-raid ,you will still need the correct firmware from win-raid .
                                  Try these:
                                  hey friend your bios work perfect the probleme is the laptop take 45 seconde to show data can u fix it pleas and thx
                                    Try this.
                                      Originally posted by imranromi View Post
                                      Try this.
                                      now it start quick but wifi dosen't work
