bios dv6-6121se
  • mahmoodjavan
    Banned
    • Mar 2018
    • 584
    • iran
    bios dv6-6121se
    hi freinds
    i need bios dv6-6121sa
    number mainboard 659998-001 cx1180
  • mahmoodjavan
    Banned
    • Mar 2018
    • 584
    • iran
    Re: bios dv6-6121se
    Originally posted by mahmoodjavan
    hi freinds
    this pic
    • mahmoodjavan
      Banned
      • Mar 2018
      • 584
      • iran
      Re: bios dv6-6121se
      plz help i need this bios
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Re: bios dv6-6121se
        you have not posted the correct mainboard code. The pic you have attached is blurry and not at all visible.
        • mahmoodjavan
          Banned
          • Mar 2018
          • 584
          • iran
          Re: bios dv6-6121se
          new pic
          https://es.aliexpress.com/item/Free-...792595092.html
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Re: bios dv6-6121se
            It would've been better if you could post the mb code which helps in giving you the exact bios. The code is on the cpu socket.
            Anyway, try this attached bios and give feedback
            • techman1025
              • Jun 2014
              • 497
              Re: bios dv6-6121se
              Here is a new update right from HP you will need to run the DMI file to add make your serial and rest of your info. Also i attached the converting FOR YOUR DELL
              TECHMAN1025
              • techman1025
                • Jun 2014
                • 497
                Re: bios dv6-6121se
                hERE IS THE NEW BIOS RIGHT FROM HP
                TECHMAN1025
                • mahmoodjavan
                  Banned
                  • Mar 2018
                  • 584
                  • iran
                  Re: bios dv6-6121se
                  TECHMAN1025
                  tanx my freind
                  • mahmoodjavan
                    Banned
                    • Mar 2018
                    • 584
                    • iran
                    Re: bios dv6-6121se
                    tankyou
                    • mahmoodjavan
                      Banned
                      • Mar 2018
                      • 584
                      • iran
                      Re: bios dv6-6121se
                      tankyou
                      • Wahaz
                        by Wahaz
                        10-30-2023, 08:42 PM
                      • thxd43
                        Lenovo laptop does not turn on, what does this number mean in a BIOS chip?
                        by thxd43
                        Hello, first of all, excuse me, I am using the translator, English is not my native language.
                        I have a Lenovo ideapad 330S - 14IKB laptop.
                        The tablet did not recognize me when I connected it, so I checked the device manager and I realized that there were many with the exclamation mark, so one by one I began to update their drivers until the sign disappeared of admiration, I even updated the BIOS, and the laptop rebooted normally and worked, so far so good, but the tablet still did not recognize me, I read on the internet that it could be due to a...
                        02-23-2023, 08:37 PM
                      • Devonavar
                        Vizio M43-C1 - How closely do I need to match the mainboard number?
                        by Devonavar
                        I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                        I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                        Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                        So, I've ruled out the PSU for now.
                        The reboot loop...
                        08-14-2022, 08:46 PM
                      • jbonavita
                        by jbonavita
                        Some issues
                        Things I tried
                        04-29-2025, 09:38 PM
                      • zenius
                        by zenius
                        12-08-2024, 06:13 AM
