Bios password remove 850 G3 HP
  • basic
    • Oct 2017
    • 229
    • 86357289244
    #101
    Re: Bios password remove 850 G3 HP
    need to remove password for this model HP 850 G3
      VIP Moderator
      • Aug 2018
      • 4386
      • Bulgaria 🇧🇬
      #102
      You messed things up a bit
      Become a Badcaps supporter
      Thanks to all supporters.​
      • daoductrong
        • Jun 2022
        • Vietnam
        #103
        Help me. Need bios 850g3
        6050a2892401-mb-a01
        • diamon
          • 107
          • Netherlands
          #104
          HP Elitebook 850 G3 Power-On password
          I have a HP Elitebook 850 G3 laptop, that gives me a Power-On Authentication message when starting the laptop (see the picture for details).
          The owner of the laptop doesn't know the password anymore (I'm certain the laptop is not stolen!).
          I have read the content of the W25Q128FVPQ chip and uploaded it also.
          Can somebody remove these passwords, I have tried it with the instructions, but did not succeed (lucky I have a backup file).
          • hardware1
            • Sep 2021
            • 2939
            • N/A
            #105
            Re: HP Elitebook 850 G3 Power-On password
            Here's your Unlocked BIOS, when the laptop start go to BIOS menu and disable security options (Default).
            If the Password still present, look for another 16MB chip and upload it's content here.
            all donations are welcome,
            • farouk_1994
              • Mar 2021
              • 392
              • algeria
              #106
              Go to security tab and restore factory settings.
              Try than replay
              • diamon
                • 107
                • Netherlands
                #107
                I have used your unlocked file, but the system does not respond when pressing on F2 or F10 (this should be the key to enter the bios).
                External keyboard and onboard keyboard the same behavior.
                • hardware1
                  • Sep 2021
                  • 2939
                  • N/A
                  #108
                  Try this one. You need to press F10 key to enter the BIOS Menu for HP devices.
                  If the problem still exist, try to disconnect any peripherals and use only an external keyboard.
                  • diamon
                    • 107
                    • Netherlands
                    #109
                    Unfortunately, still the same issue (posting).
                    I have removed the board from the laptop, and it's only the board with the LCD attached and the power button pcb with external keyboard.
                    • diamon
                      • 107
                      • Netherlands
                      #110
                      I have also uploaded the content of the other chip W25Q64FVIQ.
                      Perhaps this file needs to be changed to ?
                      • k1976
                        • Aug 2023
                        • romania
                        #111
                        Hello, smart guys!
                        I tried to make the passwordless .BIN file myself but failed.
                        So please kindly help me also to remove the password from the attached file.
                        Thank you very much!
                          VIP Moderator
                          • Aug 2018
                          • 4386
                          • Bulgaria 🇧🇬
                          #112
                          Originally posted by k1976
                          Hello, smart guys!
                          Read the chip again few times and compare the content, use verification.
                          • k1976
                            • Aug 2023
                            • romania
                            #113
                            Thank you very much for your reply!
                            I used RCUnlocker and got a passwordless .BIN file that I flashed to the chip. I have checked the inscription and there are no errors. I mounted the chip on the motherboard and all that happens is that my Caps Lock and Power lights blink somewhat regularly.
                              VIP Moderator
                              • Aug 2018
                              • 4386
                              • Bulgaria 🇧🇬
                              #114
                              It happened because your bios backup is corrupted, that's why I said to read the chip again. I can't understand why you do this, we did such detailed guides, we wrote that it is important first of all to make sure you have a verified backup and mistakes like yours are repeated again.
                              What is that haste for, you didn't make sure you have a verified file but you move on? And now what - crying game at the end as usual?
                              • k1976
                                • Aug 2023
                                • romania
                                #115
                                I apologize! Looks like I made a big mess...
                                I checked the initial bios...But it seems I wasn't careful enough...
                                Is there any chance i can fix something?
                                  VIP Moderator
                                  • Aug 2018
                                  • 4386
                                  • Bulgaria 🇧🇬
                                  #116
                                  Try this clean ME Firmware version of your dump, if it doesn't do the job, the dump must be rebuild from scratch. Erase the chip before programming, after that read the chip and compare the content, and then move on. Remove main and RTC battery before that.
                                  • k1976
                                    • Aug 2023
                                    • romania
                                    #117
                                    now i start a new procedure with the file you sent me...
                                    i deleted the bios from the chip...now i am doing the chip verification
                                    the check is ok. now I'm writing the bios you sent me
                                    I wrote your bios and checked. the check result is ok. now I insert the chip on the motherboard.
                                    • shadow225
                                      • Mar 2023
                                      • 7
                                      • cote d'ivoire
                                      #118
                                      Would you clean me region for this dump
                                      no display
                                      SN#SCG8032NX3
                                      • potforiak
                                        • Oct 2022
                                        • Slovakia
                                        #119
                                        Hi! I need remove bios password. Thank you.
                                        HP EliteBook 850 G3
                                        SN: 5CG73416BW
                                        PN: L3D24AV
                                        ME 11 version
                                          • 21037
                                          HP EliteBook 850 G3
                                          SN: 5CG73416BW
                                          PN: L3D24AV
                                          ME 11 version
                                          RCUnlocker https://www.badcaps.net/forum/troubl...29#post1594129
                                          RULES UPDATE for BIOS requests/offers AVOID BANNING, READ BEFORE POSTING
                                          https://www.badcaps.net/forum/troubl...sting?t=103570
                                          BIOS guides, methods, resources and tools
                                          https://www.badcaps.net/forum/troubl...rces-and-tools
                                          • snpetit
                                            Asus FA706IH Bios Password remove
                                            by snpetit
                                            i need some help :-/
                                            i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
                                            Could you please remove all password related stuff from this bios. A hate Asus....
                                            Thanks in advance!...
                                            01-10-2025, 09:17 AM
                                          • wishes2022
                                            Panasonic CF-SR4 CF-SR4R remove bios password or extract .exe file
                                            by wishes2022
                                            can you please remove password of CF-SR4 or extract .exe file?...
                                            05-22-2025, 08:26 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
                                          • beBoss
                                            HP ProDesk 400 G6 mini - BIOS Password attempt to remove it
                                            by beBoss
                                            as noobie to this please excuse my lack of experience.
                                            I am trying to remove a BIOS password from this machine:
                                            HP ProDesk 400 G6 Mini
                                            but so far I still have no success.
                                            I bought CH341 programmer and decided to give it a try.
                                            The programmer came with 8 pin cables and connectors or whatever everything else is called so I had to buy a new 16 pin cable because the chip which I think is the BIOS is with 16 pins..
                                            I connected everything and downloaded AsProgrammer and NeoProgrammer then installed drivers...
                                            05-30-2024, 12:48 PM
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
