HP DMI Tool NBDmiFit
  • Andreasbest
    replied
    Re: HP DMI Tool NBDmiFit
    Hello!
    I'm having a 840 G1 that uses a bios dump from 850 G1 to work (it's original bios was corrupted)
    As a result the model, serial number etc in BIOS-> System Information are all wrong.
    I'm trying to repair them with WNDMIFIT but i get error with "MPM is locked"
    I tried several ways to unlock it but no success, what do i miss?
  • groppo
    replied
    I have a hp probook 6560b and need to use DMI Tools to re-enter the details that got lost. I have made a tool but can anyone explain how I found which file to run from the DOS command when running the DMI Tools? Can I use any?
  • hammara2u
    replied
    Hi, I have HP Elitebook 840 G2. Few years back its motherboard has been replaced under warranty but they didn't put the serial number and SKU in the BIOS. I've contacted HP but they are saying that now the laptop is not under warranty and we cannot fix it.
    Can anyone please guide me step by step procedure to fix it.
    I will be really grateful to you.
  • Vesko356
    replied
  • smiley60
    replied
    Originally posted by RethoricalCheese
    First you need MPM unlocked.
    But yes, some models need to use NBDmiFit in EFI mode.
    hi sir
    how can i use nbdmifit in efi mode
  • smiley60
    replied
    Originally posted by danandrei96
    SOO.. in case anyone else is wondering, I actually managed to unlock the MPM by running UEFIMPMUNLOCK.EFI in nbdmifit 2.13 from the EFI shell. Even though the program says it's not supported on my system (2.14 would be the right version, but has no UEFI) . After MPM unlock I can use the normal tools nbdmifit or wndmifit to write the details
    how can do that teach me plz
  • pc001
    replied
    HP BIOS, wndmifit help
    Hi all, just joined as I’m looking for help with hp bios configuration after motherboard replacement.
    As I understand, the nbdmifit utility is for older laptops, I deal with newer laptops so I believe I have to use the wndmifit utility in windows.
    I have created a winpe usb and tried to run wndmifit via the cmd box but it won’t run, wndmifit runs in windows but I still need to know how to lock and unlock the mpm so I can enter the details and lock the mpm again after.
    I have tried the biosconfigurator64.exe config file edit in notepad, I edit the details in the config.txt file then save it again however I recently had an accessed denied error.
    I will be encountering hp board replacements allot so I’d like an easy / simple way of entering the sn etc.
    I have had success physically swapping the old bios chip to the new board on a few occasions but this doesn’t always work? This would be the perfect solution but for some reason it doesn’t work every time, what is the reason for this ?
    Many thanks
  • qrwvsofnbvsidof
    replied
    Originally posted by GGN
    Hello!
    I am trying to unlock the MPM on my Elitebook 840 G2 because I failed the initial branding after I changed the motherboard.
    I tried the above method, and after I launch UefiMpmUnlock.efi in EFI shell, I receive the following message: HP MPM protocol is not present.
    What do you guys think I am missing here?
    I also tried to find a way to unlock the MPM via BIOS programming with no success. Could someone tell me how to find the byte controling MPM state in the BIOS?
    Thanks!
    I'm having the same problem.
    In Windows HP BCU doesn't work nor the UefiMpmUnlock.efi (that gives me the "HP MPM protocol is not present." message).
    My HP is a business model, the 9470m on which I unlocked the bios but still I've the information missing :|
    Any idea on how to set MPM to unlock ?
  • Stangl
    replied
    Originally posted by SMDFlea
    Did you make a backup of the original bios, if so post it in the "Bios Requests" for the pass removing.
    Hi thanks for the reply, no I didn't backup the Bios. The pass is gone but the UUID is gone. I tried some version of the HP DMI, but there is no function to enter the UUID, which I saved by writing it (the original one).
    replied
    Originally posted by Stangl
    Hello everyone, I would like to ask you for help for an Hp Elitebook 8440p, which after a reset procedure of the bios pass no longer gave me the UUID (due to my fault) that during programming I did not enter it correctly. I tried with the various HP DMI, but I could not find the parameter for the UUID change there is only the choice X for the reset or to put a random one. What procedure or right program should I perform? Thank you
  • Stangl
    replied
  • steven_k
    replied
    I have an issue with my HP 255 G4. Without having replaced the motherboard i get the following error message:
    "Product Information not valid - The Following product information programmed into system board is missing or invalid
    System board (00A) Product Name, Product Serial Number, Product Number and System Board CT Number".
    When enter the bios i see born up date and factory installed os is missing too. I tried HP BCU and after enter all values and when i typed the command "/SetConfig :"filename" i got an "Access Denied" error. I want to try NBDmiFit but i don' t know which version should work. Can anyone help me, please?
  • tcsllc
    replied
    I have a HP Envy Curved All-in-one 34-b010.
    Which tool should I using to change the serial number? I replaced the motherboard.
    replied
    Originally posted by HARAN963
    I want smc.bin
    help me
    No SMC.bin files available for years. Use HP DMI tools or HP BCU .
  • HARAN963
    replied
    I want smc.bin
    help me
  • bacha
    replied
    Hello!
    I have HP Elitebook 840 g2, i have "Warning: Machine is not in committed state" on bootup i already collect thoses Infos
    Serial Number : 5CG6143X05
    Product Number : N9T65UC
    Description : HP ELITEBOOK 840 G2 NOTEBOOK PC
    IMG_BuildId BID=14WWCSDW602#SABA#DABA
    IMG_Desc1 3X47676J6b757H7M7Q7W7s7z9AaBaEawbh.r3
    any suggestion
  • M4n0l0307
    replied
    It really works, thank you very much !
  • albasiba
    replied
    Thank you
  • SKYSPB
    replied
    Product: HP 608 G1
    Operating System: Microsoft Windows 10 (64-Bit)
    Hi! After installing the modem in the tablet, the BIOS was reset.
    Product information is not valid. MPM is blocked.
    To unlock it, you need a SMC.bin Tried universal SMS.bin from the NbDmiFix utility from version 2.00 to the latest 2.14.1 I get the error SMC command failure.
    I contacted the online support service of HP, I get the answer: Your device is no longer supported.
    Please help me generate the SMC.bin
    Tablet HP 608 G1, 64 bit,
    UUID 785634123412785690ABCDDEEFAABBCC, S/N 5CD7065BXY
    Thank you!
  • SKYSPB
    replied
    Originally posted by SKYSPB
    Hello! There is an HP 608 G1 tablet. When loading, it writes: "Manufacture programming mode is in unlock". In the Readme files, it says that you need to use WinPE64 to create a bootable flash drive. Where can I download the file winpe64-2.12.zip? If you use a regular WinPE build, then wndmifit (2.10, 2.12, 2.13, 2.14) does not work. If you use the utility BiosConfigUtility64.exe then writes "System not supported". Please help me find it WinPE64-2.12.zip to create a bootable USB key. ps If you use https://docs.microsoft.com/en-us/win...pe--windows-pe Utilities also do not work. Thanks.
    Found
  • rex98
    HP DMI Tool
    by rex98
    HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
    DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
    The DMI Tool given here are for personal use only.
    DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
    You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
    from it, and that you please credit the author...
    07-02-2025, 05:51 AM
  • tsavpyn
    Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
    by tsavpyn
    Dear all,
    I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
    Now I have a problem that I am unable to dump my BIOS into bin file.
    My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
    I searched for FPT but there is no Linux version and none of them work.
    I hereby request a copy of Intel Flash Programming Tool for Linux x64.
    I would really appreciate it if anyone...
    05-28-2024, 11:18 PM
  • salim5566
    loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
    by salim5566
    Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
    06-26-2025, 03:25 PM
  • shamsudeen
    Epson M3170 Monochrome inkjet printer adjustment program tool
    by shamsudeen
    Epson M3170 Monochrome inkjet printer adjustment program tool.
    Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
    anyone having it, please share
    Thank you
    07-08-2025, 06:42 AM
  • tony359
    Best tool to place electrolytic SMD caps on a board
    by tony359
    HI all,
    I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
    When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
    The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
    01-28-2024, 06:23 AM
