HP DMI Tool NBDmiFit
    Re: HP DMI Tool NBDmiFit
    new link https://drive.google.com/file/d/19i5...ew?usp=sharing update
      upload ur old dump plz
      MOD EDIT: NO dumps in this thread, Upload to the bios requests section: https://www.badcaps.net/forum/forumdisplay.php?f=40
      How to dump my biosto file and where to upload¿¿
        Here is where bios requests go: https://www.badcaps.net/forum/forumdisplay.php?f=40 .You need to backup your bios using an SPI bios programmer.
          I have replaced my motherboard and reprogrammed the UUID, serial (except the feature byte and build Id).
          The problem is that during boot it says :
          "Warning Machine is not in committed state"
          When I open the DMI firmware tool it says MPM is not in unlocked mode and the "Commit only" button on the bottom is greyed out.
          Where can I find the feature byte and build Id how can I unlock MPM? I read SMC.bin has to be generated based on the UUID and the SN
          This is my problem also with factory new 1040 G1 motherboard.
          I need to reunlock MPM to correct the fields.
            See post #137 .Whats your serial number ?
              Originally posted by smdflea View Post
              see post #137 .whats your serial number ?
              2ce4210ns1
              That post is to lock the MPM
              I need to unlock. Tried every method. No success. The MPM locked
                Send error bios file i will fix or remove error.
                  The problem is I added the SKU in the wrong format and locked the MPM
                  This caused not in commited mode error.
                  I don't want to deal with DUMPS, I prefer the original method.
                  If no any other way I will dump the chips.
                  This was factory new replacement motherboard from HP
                    If you done without bios dump tell me i wait..
                      I can done without dump if I have the correct SMC.bin file. That will unlock the MPM again and I can modify the faulty settings with HP DMI Tool. Lock the MPM again and every boot error will disappear
                      Just need the generated SMC.bin file for my serial and UUID
                        This is current bios. Latest version. Machine not in committed state!!
                        Featurebyte and Build ID missing. MPM locked
                        I don't know exactly whats the problem. SKU format is invalid or what??
                        MOD EDIT: Bios requests go in the "Bios Requests ONLY!" section, not in this thread
                          Read bios chip via programmer.You save file without programmer..
                            Yes I know but if I read the chip and open wit hex editor, its only zeros, can't see any content. I have multiply programmers and softwares.
                            Always have difficulties with this 1040 G1 and G2
                            In my case the problem is Machine not in committed state because I have not set the vPRO functionality and locked the MPM
                            If I unlock the MPM again I can commit the board and voila. Problem solved.
                            What can you do with the dump?
                            https://youtu.be/Q1tMphdzTIo
                              i can solve all problem via bios dump.read complete bios and send if you want solve problem.No have other way if you want waste time you can try via software.
                                Okay I can read the chips but how? Both of my programmer read out looks like nothing...
                                Okay I will send you the dump and you will check it.
                                    I don't request bios.
                                    I just like to get my problem solved. Locked MPM to Unlocked MPM
                                      Here is the dumps https://www.badcaps.net/forum/showthread.php?t=88318
                                        i dumper and uploaded my bios
                                        https://www.badcaps.net/forum/showth...517#post986517
                                        please unlock my MPM,
                                        many thanks
                                          many thanks
                                          Sorry MPM unlocking only possible with SMC.bin file which is unique for each unit generated from serial and UUID. Only HP can do.
