dv7-3165el bios dump
  • Hdg
    • Oct 2007
    • 9
    Hello.. anyone have dv7-3165el bios dump? thanks
  • sancheti81
    • May 2014
    • 191
    • India
    Re: dv7-3165el bios dump
    try this
    • Hdg
      • Oct 2007
      • 9
      the official bios doesn't work.. size is also bigger than rom
      • sancheti81
        • May 2014
        • 191
        • India
        post your old bios
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          The bios posted by sancheti81 is 2mb which is correct and i dont see any reason for hp official bios not working. Perhaps not a bios issue.
          • Hdg
            • Oct 2007
            • 9
            because i've to program it with an eprom programmer
            • String2016
              • Nov 2015
              • 2229
              • philippines
              the program above is working because it's from official hp site maybe your problem is not in the bios if you are sure that is bios problem post your old dump here, maybe someone can fix.
              • sancheti81
                • May 2014
                • 191
                • India
                you can rename .fd file extension to .bin
                • DynaxSC
                  by DynaxSC
                  11-17-2023, 10:56 AM
                • grimacelord
                  Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                  by grimacelord
                  This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                  Motherboard model number: DA0PAMB46A1 REV: A
                  Secondary motherboard model number: 0PAB
                  SKU: 685K4UA
                  Serial number is: 5CD3223BJP
                  Recently reflashed this laptop with latest BIOS and once...
                  05-07-2024, 08:06 AM
                • DynaxSC
                  Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                  by DynaxSC
                  I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                  It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                  I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                  11-06-2022, 05:22 PM
                • vinaypundith
                  Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                  by vinaypundith
                  I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                  So, I'm looking for a BIOS dump for this machine - a 16MB one....
                  08-03-2024, 12:32 PM
                • Buzzfuzz2k
                  Bios password removal on a Unowhy dump
                  by Buzzfuzz2k
                  Hi Everyone,
                  I'm facing a problem with a locked bios with a password and i can't find how to remove it...
                  The small computer is only booting on a M2 ssd Windows partition and i get a "signed partition error" if i try to boot on the same SSD with another Os (linux for example).
                  the Computer is a Unowhy small pc
                  N° UYM6524702229
                  After failling trying to boot on other "none Windows" partition, i wanted to try to remove the bios password.
                  My first attempt was to get the bios dump from windows...
                  11-13-2023, 07:37 AM
