Remove_SMM... UEFI.
Re: Remove_SMM... UEFI.
Originally posted by kiknusko View PostI Can unlock your ntb for free send me your BIOS dump and model
I got an T480s that Lenovo sent out as a replacement for an old T460s that died and the T480s came with a supervisor password from the refurbishing center in China.
Originally posted by benderc View PostFairly new here, but I'm also interested in this if you are willing to help me
Originally posted by RethoricalCheese View PostBetter upload your bios dump. Got to modify that file.
https://www.mediafire.com/file/7rdx2...s-org.zip/file
So this is the LenovoTranslateService file I patched so it would accept any key.
I did test it on X260 and it did work well. But when I tested it on X270, there would be beeps but no display.
I know that 6th, 7th and 8th gen share the same LenovoTranslateService and BootOptions file (I compared patched files for different models). There may be another file needed ?!Attached Files
Originally posted by RethoricalCheese View PostSo this is the LenovoTranslateService file I patched so it would accept any key.
I will try it on my x250 when I receive my new programmer..
Don't forget BootOptions and SystemPpisNeededByDxe which are found in some previous post in this topic.
Originally posted by RethoricalCheese View PostFor that model you might need different file. I am not sure because I haven't compared 4th/5th gen to 6th/7th/8th gen yet. But try it first and let me know.
Originally posted by RethoricalCheese View PostWell, good point. If uefitool is used then it is actually not needed because when BootOption is replaced in Uefitool, SystemPpisNeededByDxe gets modified automatically anyway.
Or give me email i have some info about toshiba i know you interested this topic or i not have option i contact pm or email.
my email:*********************Last edited by imranromi; 10-13-2019, 12:34 PM.
The last 3 posts about Toshibas have been deleted,they`re all off topic and not related to this thread.
Start a new thread.Last edited by SMDFlea; 10-17-2019, 09:24 AM.
@RethoricalCheese - Do you know if your patched file works on both 7 and 9 digit ID's, or does that not matter and as long as file is compatible with system it should work?
I don't need right now, can't test, only following along to try and learn and or help, to be able to sort this out for others later who need unlocked.
What you did was my first thought too, jump different or bypass area, before it was mentioned on page 1 post #11 - good to see that was a good idea and it's now proven working method at least on some systems.
I guess from my end, it doesn't help that I'm not familiar with these models or what generation is what
We need to put together a package of files xx1 set for xxgen1/models and then another for xx2 set for xxgen2/models.
If you need help trying to figure out how to patch anything let me know, I am good at than kind of thing too, but do not own any of these systems (only help people with BIOS often)
Originally posted by RethoricalCheese View PostBIOSG3tta3, it doesn't matter which one.
dwirachmat, yes it will ask for key but it accepts any key. And yes, it will say invalid but it continues to the valid part right after that. Did you replace BOTH files or just LenovoTranslateService?
so maybe when it stuck on invalid key, i must shut it down and reflash with original bios right? or how?
