Remove_SMM... UEFI.
https://www.badcaps.net/donate -
https://www.badcaps.net/donateComment
Re: Remove_SMM... UEFI.
hello, i have a thinkpad x1 carbon 3rd gen. (20bs) it has a fingerprint lock in bios, if i skip fingerprint check it has a bios password. Don't really know more about the bios setting, since i cannot enter bios even in read-only mode. When i enter 3 incorrect passwords it just restarts. I patched the bios file and used ch341a to write it directly on the chip. I get 5 + 5 beeps and no display. After that, i wrote original bios and it's working the same as before (locked bios). I have attached original bios and patched bios. I think it might be me region lock can anyone help with it?
Hello, I think your problem is that your BIOS file does not contain any Intel firmware ME region.
Please check it yourself with the ME Analyzer
https://github.com/platomav/MEAnalyzerComment
Is there a solution for L14 gen 1 to remove the bios password?
https://www.badcaps.net/forum/showpo...postcount=1426
thxComment
Try to use the Auto-Patcher next time, so that the resulting patched bios files do not require a KEY.
Who patched your bios file? In order to know which algorithm to use. Provide a Hardware ID and I will provide you with the KEY, remember that BACKSPACE key do not work to correct a mistyped KEY.Comment
i have the original hardware id and the first key, but the computer sat for awhile and was unresponsive so i reboot it. original Hardware id 1809260 and original key 1369857. While the first id was on the screen the computer sat for too long became unresponsive so i rebooted then tried putting in the key i got not realizing that the id regenerates when rebootedLast edited by ronlater; 04-23-2022, 12:28 AM.Comment
by GuiTiHey everyone!
I need help with my Lenovo Chromebook 100e Gen 3.
Here are the details:- Motherboard: LA-L131P
- MFG Date: 2022/01/07
- MTM: 82J80001BR
- MO: MPNXB2103001
- Factory ID: LI123
I bought a new Winbond 25Q128FVSG chip.
The chip currently on the board is the same model but with different ending letters.
I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
The Chromebook is Google account locked, and I’ve already tried everything.
I understand that I need to replace or...-
Channel: BIOS Requests ONLY!
by DynaxSCHi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent... -
by m3vuvIts a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
07-15-2024, 10:15 AM -
by CronaxFDHey guys,
Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
From what I've... -
by S70rm7r00p3rHi guys.
I am very new to this business and i have some questions. Maybe someone can help me further.
I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
- Loading...
