Remove_SMM... UEFI.
  • hoaca388
    Badcaps
    • Jan 2022
    • 11537
    • Viet Nam
    #1561
    Re: Remove_SMM... UEFI.
    Originally posted by vignesharivuslm
    t490, i7 8th gen cpu, nm-b901 patch pls, dxe autopatcher not work.
    • hoaca388
      Badcaps
      • Jan 2022
      • 11537
      • Viet Nam
      #1562
      Originally posted by ak1_2004
      e595 !
      Autopatcher dont work !
      • hoaca388
        Badcaps
        • Jan 2022
        • 11537
        • Viet Nam
        #1563
        Originally posted by fraymaker
        hello, i have a thinkpad x1 carbon 3rd gen. (20bs) it has a fingerprint lock in bios, if i skip fingerprint check it has a bios password. Don't really know more about the bios setting, since i cannot enter bios even in read-only mode. When i enter 3 incorrect passwords it just restarts. I patched the bios file and used ch341a to write it directly on the chip. I get 5 + 5 beeps and no display. After that, i wrote original bios and it's working the same as before (locked bios). I have attached original bios and patched bios. I think it might be me region lock can anyone help with it?
        • ak1_2004
          • Oct 2017
          • 41
          • Iran
          #1564
          Originally posted by hoaca388
          Dont work !
          if can you help me to edit manual this bios dump .thnx
          • Markus1741
            • Sep 2020
            • 843
            • N/A
            #1565
            Dont work !
            if can you help me to edit manual this bios dump . i can pay $ to you !
            thx
            Hello, I think your problem is that your BIOS file does not contain any Intel firmware ME region.
            Please check it yourself with the ME Analyzer
            https://github.com/platomav/MEAnalyzer
            • ak1_2004
              • Oct 2017
              • 41
              • Iran
              #1566
              E595 AMD CPU Laptop
              • hoaca388
                Badcaps
                • Jan 2022
                • 11537
                • Viet Nam
                #1567
                E595 AMD CPU Laptop
                System with AMD cpu have no ME ( Intel Manager Engine )
                • datodati962@gmail.com
                  • May 2020
                  • 48
                  • alb
                  #1568
                  Originally posted by Maxpower3
                  Update V3 !! (read above)
                  Only for Windows
                  Fix problem with python
                  Please Test and report
                  please update the link
                  • danito
                    • Jun 2016
                    • 881
                    #1569
                    Is there a solution for L14 gen 1 to remove the bios password?
                    https://www.badcaps.net/forum/showpo...postcount=1426
                    thx
                    • ronlater
                      • Apr 2022
                      • 10
                      • canada
                      #1570
                      Hi there you couldnt generate a key for me could yoou please. Hardware id is <2809280> i just geenerated this hardware id i and wont turn the compter off
                      • AAAC
                        • Jan 2020
                        • 458
                        • Mexico
                        #1571
                        @ronlater
                        The files are patched, so that you only have to press ENTER key to complete the unlock, no KEY is needed as far as I know... try.
                        • ronlater
                          • Apr 2022
                          • 10
                          • canada
                          #1572
                          It just said invalid key
                          • AAAC
                            • Jan 2020
                            • 458
                            • Mexico
                            #1573
                            Try to use the Auto-Patcher next time, so that the resulting patched bios files do not require a KEY.
                            Who patched your bios file? In order to know which algorithm to use. Provide a Hardware ID and I will provide you with the KEY, remember that BACKSPACE key do not work to correct a mistyped KEY.
                            • ronlater
                              • Apr 2022
                              • 10
                              • canada
                              #1574
                              Ok It was patched by someone from vinafix.Is there a tutorial on how to use the auto patcher. My hardware id is 7713780
                              • AAAC
                                • Jan 2020
                                • 458
                                • Mexico
                                #1575
                                (Hardware ID: 7713780)
                                The KEY is: 8369400
                                • ronlater
                                  • Apr 2022
                                  • 10
                                  • canada
                                  #1576
                                  It said invalid key
                                  • AAAC
                                    • Jan 2020
                                    • 458
                                    • Mexico
                                    #1577
                                    Do you have a Hardware ID + matching KEY that you have used before?
                                    • ronlater
                                      • Apr 2022
                                      • 10
                                      • canada
                                      #1578
                                      i have the original hardware id and the first key, but the computer sat for awhile and was unresponsive so i reboot it. original Hardware id 1809260 and original key 1369857. While the first id was on the screen the computer sat for too long became unresponsive so i rebooted then tried putting in the key i got not realizing that the id regenerates when rebooted
                                      • AAAC
                                        • Jan 2020
                                        • 458
                                        • Mexico
                                        #1579
                                        Verify, the closest match I get is this one:
                                        (Hardware ID: 1809260)
                                        The KEY is (new-A): 1369856
                                        Post a new Hardware ID and wait for the KEY.
                                        • ronlater
                                          • Apr 2022
                                          • 10
                                          • canada
                                          #1580
                                          1369857
                                          Enter and
                                          Press 2x space bar when asked. Turn off the computer.
                                          and restore your original bios . Done:
                                          thats what i got for the original key. do you think it could have been a typo
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
                                          • S70rm7r00p3r
                                            Intel NUC NUC6i3SYH UEFI Update went wrong
                                            by S70rm7r00p3r
                                            Hi guys.
                                            I am very new to this business and i have some questions. Maybe someone can help me further.
                                            I have a 2015 Intel NUC NUC6i3SYH and for some internet and office the computer works perfectly. Lately it has been bugging me a bit on and off. Then I saw there is a UEFI update from Intel and I thought if I put it on, the problems might be gone, but unfortunately the update didn't go through. The screen stayed black and after waiting for a while nothing happened, I had to pull the plug at some point. Of course, the NUC then failed to boot!
                                            03-19-2022, 08:59 AM
                                          • hinsech475
                                            Fujitsu LIFEBOOK AH562-UEFI problem-Help request
                                            by hinsech475
                                            Hi, I would appreciate your help with the following problem.
                                            I have a Fujitsu laptop AH562 witn a BIOS-UEFI problem since I converted the HDD to a SSD. For more details on the paltop go to the following link:
                                            http://support.fujitsupc.com/CS/Port...srch=TECHSPECS
                                            After copying the HDD to SSD with ALtiris utility provided with the Kingston SSD and replacing the HDD with the SSD the laptop went into a startup loop with no screen display and only the disk LED flashing twice per second. I waited for approximatly 2h and then stopped the laptop...
                                            06-03-2018, 10:57 PM
