Remove_SMM... UEFI.
  • Karol
    • May 2016
    • 90
    #781
    Re: Remove_SMM... UEFI.
    Originally posted by alqotary
    ThinkPad T430
    Here you have point connection for SCL SDA from security eeprom L08
    I here from the internet that if you keep connected SCL & SDA together. And start the notebook with F1, you can bypass the password and change it.
    I never did this. So you have a risk.
    Joe's KMX1 Pro S, RevelprogIS, TL866II, CH341A, Vertyanov JIG 3.1, Eakins Microscope, Gordak 952, 30V/5Ah PSU, 890C+, T2L Thermal Camera, SVOD 3, etc.
    • alqotary
      • Jun 2016
      • USA.
      #782
      I know the away but I want try ThinkPad T430 Patch
        • 22030
        The pass will still be there on the L08 chip,no point patching the bios.
        • holu00
          • May 2020
          • 9
          • Mexico
          #784
          I have decided not to provide any dump here because for me it's not clear what steps are performed with this dump. The steps from this thread did not work for the L560. I will leave the laptop locked as it is if the activation of the ATA security will also not help. Another idea is to buy a new motherboard. I don't like it but this gives me full control.
          Good luck for other users who want to learn by themselves.
            • 22030
            See post 7 and 9 https://www.badcaps.net/forum/showthread.php?t=84383
            • holu00
              • May 2020
              • 9
              • Mexico
              #786
              Originally posted by SMDFlea
              Thanks! I will have a look.
              • Karol
                • May 2016
                • 90
                #787
                You make a big confusion. It's about L560. Not about L540
                L560 it doesn't have EEPROM
                Many beginners make confusion beetwin SPI flash 25Xxxx and EEPROM's, and they short the BIOS chip.
                holu00
                I suggest you to leave HDD/SDD removed from your notebook. Start and check if you have password without HDD.
                If you have password patch the BIOS, run it, put back the original BIOS and check if password is gone. If it is, put back your HDD. If ask for password is clear that your HDD is password protected.
                Do you know to use UEFITool ?
                  • 22030
                  holu00
                  Oh i guess you`re right, my bad .
                  • lap12
                    • Mar 2019
                    • 40
                    please need patched file
                    • Ghamidi
                      • Mar 2020
                      • 306
                      • France
                      #790
                      try this file and valid with any key
                      • jayjayuk
                        • Nov 2013
                        • 16
                        #791
                        Please can someone patch this one?
                        • Karol
                          • May 2016
                          • 90
                          #792
                          Let's try !
                          • lap12
                            • Mar 2019
                            • 40
                            please patch it x270
                            • jayjayuk
                              • Nov 2013
                              • 16
                              #794
                              Let's try !
                              Thanks, flashed this but 5 beeps and black screen.
                              • Karol
                                • May 2016
                                • 90
                                #795
                                I take a look to T490 BIOS. I find two LenovoTranslateService and two BootOptios, I compare and look the same.
                                Did someone try to patch all 4th of them?
                                • Karol
                                  • May 2016
                                  • 90
                                  #796
                                  Another file if you want to test
                                  • jayjayuk
                                    • Nov 2013
                                    • 16
                                    #797
                                    Thanks for your efforts in helping, it's much appreciated/
                                    One question, i've been studying previous modifications of the X1 Yoga and they all appear to have had the VSS2 Certificate store deleted, however the ones here which you patched when i open with UEFItool still show them there.
                                    I think this might be an issue
                                    • aldopc
                                      • Jul 2017
                                      • 477
                                      • Chilito
                                      #798
                                      Try this
                                      • aleksandaralex
                                        • Jan 2016
                                        • 10
                                        • Serbia&Montenegro
                                        #799
                                        Please patch for this bios dump, think T460,
                                        Thank you very much.
                                        • alqotary
                                          • Jun 2016
                                          • USA.
                                          #800
                                          I need patch ThinkPad X1 Carbon 4th Gen please
                                          • nikola386
                                            Introducing Repair Assistant - A Free, Open Source Management System Built for Electronics Repair Shops
                                            by nikola386
                                            Hey BadCaps community, I built Repair Assistant, a management system for electronics repair shops. It covers tickets, customers, inventory, expenses, and reporting. What it does:
                                            • Repair ticket management — Track repairs with device details, status, priority, and notes
                                            • Expense & profit tracking — Track parts and labor per ticket with automatic profit calculations
                                            • Customer management — Database with contact info and repair history
                                            • Inventory tracking — Manage parts and components
                                            • Business analytics — Real-time stats, financial overview, profit margins, and trend charts
                                            • Professional
                                            Yesterday, 02:52 PM
                                          • GuiTi
                                            Need Custom BIOS (UEFI/Dualboot) for Lenovo Chromebook 100e Gen 3
                                            by GuiTi
                                            Hey everyone!
                                            I need help with my Lenovo Chromebook 100e Gen 3.
                                            Here are the details:
                                            • Motherboard: LA-L131P
                                            • MFG Date: 2022/01/07
                                            • MTM: 82J80001BR
                                            • MO: MPNXB2103001
                                            • Factory ID: LI123
                                            I bought a new Winbond 25Q128FVSG chip.
                                            The chip currently on the board is the same model but with different ending letters.
                                            I can’t use the CH341 clip on the chip that’s on the board because it’s too low-profile and doesn’t make proper contact.
                                            The Chromebook is Google account locked, and I’ve already tried everything.
                                            I understand that I need to replace or...
                                            10-14-2025, 08:41 AM
                                          • DynaxSC
                                            Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                                            by DynaxSC
                                            Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                                            For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                                            06-10-2023, 11:30 AM
                                          • m3vuv
                                            getting an hp elitebook 8730w to work with a gpt drive with uefi
                                            by m3vuv
                                            Its a bit of a long tale but i swapped the original hd for a 2tb ssd,i want about 6 bootable partitions,it needs the uefi enabling in the bios,I am ok with that,the issue is i cant convert the drive to gpt when it has data on it,the issue is windows wont install to a gpt drive,there is a utility from hp to install the efi partition on the drive but it runs on windows,its a chicken and egg thing,can anyone explaine how hp did this?,I am pulling my hair out;it seems i need to run the hp uefi tool to make the uefi option work in the bios, but it needs windows to run this that wont install on a gpt...
                                            07-15-2024, 10:15 AM
                                          • CronaxFD
                                            Is unlocking UEFI worth the hassle? (Surface Pro 4)
                                            by CronaxFD
                                            Hey guys,
                                            Bought myself Surface Pro 4 tablet today on a local craigslist-type website.
                                            I've seen that UEFI was password protected and of course the seller forgot the password, but decided to buy it anyway.
                                            Really needed such a tablet to use with RomRaider to do some logging/tuning on my car.
                                            It has secure boot turned off and boots from USB, so I've formatted SSD and have done clean win10 install.
                                            Works fine, but wanted to ask, are there any real security risks associated with UEFI settings on Surface (remote access etc.)?
                                            From what I've...
                                            03-14-2024, 12:42 PM
