ASUS K52F - V2.0 tested and working dump
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    100% working dump
  • daniello
    • Nov 2017
    • italy
    Re: ASUS K52F - V2.0 tested and working dump
    Originally posted by Pragmatiko
    100% working dump
    grazie da italia
    • whitevolf
      • Feb 2014
      • 124
      • TÜRKİYE
      thanks
      • tojikatonoji
        • Sep 2017
        • 19
        • türkiye
        thanks
        • shaon_kof
          • Feb 2014
          • 41
          • Bangladesh
          100% working dump
          Your dump file size is not accurate.
          • amansr12
            Asus Rog strix G513 keyboard, fans not working, battery not charging, works on ac
            by amansr12
            Hi, I recently open my Asus rog strix g1513 laptop to clean the fans and while disconnecting the battery there was a spark near the connector (c6000) and a capacitor (C60050 ) and the keyboard , fans stopped working and the laptop only works when charger plugged in, otherwise no. I removed the burned capacitor and the nearby caps stopped shorting but the problem didn't go away when I turned the motherboard some capacitors ( c8047 c8048 c8049 c8050 c8051 c8053 - connected to pin 25 and 57 of the u8003(ite252e248a) and c8023 c8024 c8046 connected to pin 24 ) are shorting ,,,,pin 26 is ground...
            11-20-2025, 09:38 AM
          • mkdj
            by mkdj
            Dear all,
            10-19-2025, 04:41 AM
          • ArkzG
            [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
            by ArkzG
            Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
            What I currently have available:
            - Model: FA506NF (2021)
            - BIOS chip: GD25LQ16 (16Mbit/2MB)
            - Tools: CH341A programmer ready to use
            Does anyone have either a clean 2MB .bin dump of this model,...
            09-26-2025, 09:34 PM
          • kodox
            Asus ExpertBook B1400CB Bios Dump Needed
            by kodox
            need original bios dump, original bios has flashed by other technician before me.
            attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
            unit info:
            Model: Asus ExpertBook B1400CBA-0711A1235U
            S/N: R6NXNZ006657238
            CN: 7F6F
            Mainboard Code: B1500CBA R2.1...
            08-16-2025, 12:20 PM
          • DynaxSC
            ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
            by DynaxSC
            I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
            Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
            Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
            The behaviour is also really very strange, i.e.:
            • The disk shows always up in BIOS - so it is recognized, so far so good
            • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
            02-23-2025, 01:33 PM
