acer e5-473g bios needed
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    Re: acer e5-473g bios needed
    maybe that is the only solution because mine i have already returned the laptop to client
    • gustarom
      • May 2013
      • 44
      • indonesia
      Try.Good luck bro.
      thanks
      • hengkyzhu
        • Jul 2018
        • Indonesia
        Originally posted by imranromi
        Try this if not solve not bios problem.
        thanks
        • ravenmx
          • May 2018
          • 170
          • puebla
          try this tested works. bios + ec ENE kb
          • HarryPK
            • Mar 2014
            • 210
            • barabai
            vga or cpu problem, that is the common problem for this board. reball or replace it.
            • markgil15
              • Mar 2023
              • Philippines
              #26
              Anyone fix this issue on this board?
              • EbrahimSiami
                Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                by EbrahimSiami
                I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                **What I have tried so far:**
                1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                07-02-2025, 02:31 PM
              • NecroFlex
                Acer Aspire 1 A115-32-C28P BIOS needed please
                by NecroFlex
                I have an Acer Aspire 1 A115-32-C28P laptop that tries to boot for 5s and then shuts off. (Mobo name GH5JJ/GH7JJ LA-K701P Rev C1)
                I suspect the BIOS might be the issue, but ACER website doesn't come with a BIN file, only an EXE that doesn't contain the full image. I tried searching for a BIOS bin but no luck.
                I have attached both the bios i read from the chip and the latest ACER bios. Thanks for any help in advance!...
                02-11-2025, 08:51 AM
              • Loli Popu
                DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                by Loli Popu
                Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                12-13-2024, 03:28 AM
              • drux
                Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
                by drux
                I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
                Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
                These models have AMI/Aptio BIOS.
                Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
                11-03-2024, 01:18 AM
              • tlindi
                Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                by tlindi
                Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                Ack
                Ack
                01-30-2025, 04:26 AM
