I need asus x202E rev.2.1 bin
  • eyes25
    • Nov 2016
    • 9
    • phillippines
    model : x201e
    board code : x202E IO Board REV. 2.1
    tnx
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: I need asus x202E rev.2.1 bin
    try this
    • by_mex
      • Feb 2014
      • 57
      • turkey
      Thx bro
      • toufik sat
        • Feb 2016
        • 134
        • los angles
        Grazie
        • vhunter
          • Aug 2020
          • CAMEROON
          Good Morning,
          Can I have bios flashing procedure for this asus model???
          The one am working on, power on but doesn't display
          • peste
            • Dec 2016
            • 12275
            • ROMANIA
            Originally posted by vhunter
            Good Morning,
            try the one from post # 2, but first make a copy of the original bios.
            • vhunter
              • Aug 2020
              • CAMEROON
              I have already downloaded the bios firmware, but am looking for the procedure. Should I use CTRL+WINDOWS combination???
              • peste
                • Dec 2016
                • 12275
                • ROMANIA
                you need an SPI programmer, open the laptop to remove the bios chip to make a copy to write the bios chip from post # 2 ,,, etc ... more information and video can be found on the net..
                https://www.youtube.com/watch?v=DWWigscuQDY
                • mberbouch
                  • May 2014
                  • 107
                  • Morocco
                  try this
                  Thanks Bro, it's working 100%
                  • m1ch43lzm
                    by m1ch43lzm
                    05-12-2025, 08:37 PM
                  • DynaxSC
                    ASUS STRIX Z490-F GAMING - No POST, stubborn board
                    by DynaxSC
                    I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
                    The situation looks like this:
                    After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
                    1. RTC oscillates normally (32.768KHz).
                    07-08-2022, 05:45 AM
                  • ShadowAi12
                    ASUS ROG STRIX B550-F GAMING — Board not powering on properly
                    by ShadowAi12
                    I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
                    • The board enters a "ready to power on" state after plugging in the PSU.
                    • Pressing the power button increases power draw.
                    • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
                    Measurements:
                    (taken after pressing the power button, while the board is attempting to start)
                    • H_SKTOOC#
                    06-11-2025, 01:05 PM
                  • jimbodriver
                    Faulty ASUS X99-PRO board. Some progress with repair. Need advice\help please.
                    by jimbodriver
                    I am trying to learn electronics repair. I purchased a “faulty for spares/repairs” ASUS X99-PRO/ USB 3.1 motherboard for a very low price from ebay – a good enough price to offset the high probability that the board was completely toast and not realistically repairable.
                    Initial results:
                    Board would power-cycle when turned on either with switch on board or shorting pwr pins. Fan would spin for a second or so and a QCODE of 00 would display then it would power off and then do the same thing again over and over. I think maybe 2 times in about 100 attempts...
                    03-20-2022, 02:30 PM
