How to flash/reset Zed Air Bios
  • nlepathy
    • Jun 2017
    • Seychelles
    I just bought an i-life Zed Air laptop and I have accidentally disabled the Video Driver in the Bios. Now I cannot see anything when I start the laptop (Black Screen), so I cannot go back to Bios setting to re-enable the driver. Can anyone help me as to how I can reset/flash the Bios?
    Thank you.
  • walupapz
    • May 2017
    • 21
    • philippines
    Re: How to flash/reset Zed Air Bios
    first you should dismantle your zed air until you see the motherboard then find the 8 pins bios mine i found my zed air bios at the other side of the motherboard ..the 8 pins bios there are some labeled HOLD CLK C1 and so on.if you found your bios press power on wait till it display then get a tweezeer or a screw that can short 4 pins of the bios try first pin 1234 short them wait till the laptop goes power off then there you go your bios settings will go reset deafaullts ..this will apply to those disabled keyboard mouse nom videos
    • walupapz
      • May 2017
      • 21
      • philippines
      if pin 1234 not work try short pins 5678 4pins must be short wait till laptop goes power off
      • walupapz
        • May 2017
        • 21
        • philippines
        i found this method when i accidentaly change settings in bios of my zed air like "fastboot os" and disabled usb 3.0 " im so frustrated then i tried to short pins of bios thats all and my keyboard and mousepad comes back working again
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          By using this method, it is also possible that the Bios chip becomes faulty. So first, create a backup of Bios.
          • walupapz
            • May 2017
            • 21
            • philippines
            nope my laptop is 100% working
            • Sophisticated
              • Apr 2018
              • Nigeria
              Hi, I found the bios, mine is labelled HOLD CLK D1. I tried shorting the four pins, didn't work. Has anybody tried it already, is there something else I can try? Many thanks in advance.
              • tanzeelsg
                • Mar 2019
                • Pakistan
                I have a zed note sb 11.6" too and as i changed the vga settings, now i am unable too see display on my touch screen. i contacted iLife support they say they don't have a solution for it.
                I wanna know if combination of keys or any usb bootable program is there that can help me to reset bios settings to its defaults without looking at the screen as there is no backlight now.
                please assist
                  by Vesko356
                  08-11-2023, 03:27 AM
                • AkaBukai
                  Is it okay to flash stock bios onto the motherboard's BIOS?
                  by AkaBukai
                  Hi there,
                  I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                  The little LED on the power button is flashing slowly and nothing happen.
                  This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                  So I decided to flash the BIOS using a cheap programmer.
                  And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                  I also...
                  12-19-2024, 12:15 PM
                • YG007
                  Asus BIOS How To Reset To Default Settings?
                  by YG007
                  Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
                  I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
                  06-05-2023, 08:22 PM
                • James Jackson
                  Panasonic CF-20G0247VM BIOS Bad Flash Help
                  by James Jackson
                  I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
                  Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
                  05-01-2025, 11:28 AM
                • spmetroil
                  Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
                  by spmetroil
                  I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
                  The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
                  I have a CH341A programmer and I already attempted the following steps:
                  1. Identified the correct chip (W25Q128, 3.3V SPI flash).
                  2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
                  3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
                  08-19-2025, 09:23 AM
