HP Elitebook 8560p Bios Dump
  • peste
    • Dec 2016
    • 13451
    • ROMANIA
    Re: HP Elitebook 8560p Bios Dump
    put it as corrupt as it is ... we have no way to help you, if we don't know what you need ..
    • blazzelia
      • Nov 2019
      • 40
      • Romania
      Well, there is an archive attached to this thread, in the second post. The file in it is larger than the size of the BIOS chip this motherboard has.
      The chip is a MX 25L6406E and you can fit in it a 8192 Kbytes file. The file in the archive has 8196 Kbytes so it won't fit. That's the part I need help with.
      As for the reading of the original BIOS chip, I didn't do that as my chips programming setup is primitive and requires soldering wires. I just had an identical chip which I used to write the bin file then I replaced the chip on the board. But the laptop is still not working so I came back to this post because of the dump file attached ...
      • blazzelia
        • Nov 2019
        • 40
        • Romania
        I was able to read the original BIOS chip and here is the content.
        • peste
          • Dec 2016
          • 13451
          • ROMANIA
          give it a try and we'll see ..
          • blazzelia
            • Nov 2019
            • 40
            • Romania
            It works, thanks. My I ask what you changed?
            • Sergio1985
              • Aug 2019
              • 5
              • Bosnia
              #26
              Thanks a lot. Works great
              • c.daniel
                • Mar 2017
                • 108
                • Romania
                #27
                Originally posted by techman1025
                Hi
                Always upload original it's a lot harder with out it even if it's bad.
                Techman1025
                techman1025, thank you very much man, it's working perfect
                • yoseef
                  Banned
                  • Aug 2019
                  • 9
                  • 88883656258
                  #28
                  Thank you
                  • Daudi83
                    • Dec 2018
                    • 66
                    • Hungary
                    #29
                    Hello. I have a same model with password and cannot boot from usb. Can anybody help to remove the password for me? I really appreciate it.
                    • qayyum786
                      • Aug 2018
                      • 1959
                      • INDIA
                      #30
                      Originally posted by daudi83
                      hello. I have a same model with password and cannot boot from usb. Can anybody help to remove the password for me? I really appreciate it.
                      try
                      • Daudi83
                        • Dec 2018
                        • 66
                        • Hungary
                        #31
                        Thanks i will check tomorrow.
                        • Daudi83
                          • Dec 2018
                          • 66
                          • Hungary
                          #32
                          Thanks Gayyum its work like a charm
                          • hussaka
                            • Jan 2015
                            • 154
                            • italy
                            #33
                            thank you
                            • bdschemetic
                              • Sep 2018
                              • 24
                              • bangladesh
                              #34
                              hp elitebook 8560p
                              hp elitebook 8560p
                              e89382 hannstar j mv-6 94v-0 bios bin & schemetic please
                              • peste
                                • Dec 2016
                                • 13451
                                • ROMANIA
                                #35
                                Re: hp elitebook 8560p
                                Originally posted by bdschemetic
                                hp elitebook 8560p
                                https://www.badcaps.net/forum/showth...litebook+8560p
                                • abacom
                                  • Aug 2020
                                  • 3
                                  • nigeria
                                  #36
                                  Originally posted by qayyum786
                                  try
                                  hello qayyum pls does it works for 8560p motherboard with amd vga chip or its only applicable to intel only
                                  • qayyum786
                                    • Aug 2018
                                    • 1959
                                    • INDIA
                                    #37
                                    I have just unlock the password from dump
                                    btw you can write & test it if it is work for you than awesome
                                    if not than post your laptop model/number/mbd part number & backup dump we will try to fix it or build it again for you
                                    • Maikl
                                      • Jan 2020
                                      • Czech Republic
                                      #38
                                      Hello, could anyone help me and modify the serial, pn .etc to get rid of the message product information not valid.
                                      It is not possible to write via the HP DMI Tool, so I test directly via the bios.
                                      Thank you very much.
                                      My bios and values.
                                      HP EliteBook 8560p
                                      Serial: 5CB1505ZP8
                                      Product: WX788AV
                                      Warranty:3y3y0y
                                      Motherboard:
                                      CURE_DIS_HR_HPB MV_MB-V1
                                      P/N: 01015FM00-388-G
                                      • dahnking
                                        • Apr 2018
                                        • 262
                                        • kenya
                                        #39
                                        Hi
                                        Techman1025
                                        Thank you
                                        100% working
                                        • Usedcom
                                          Usedcom
                                          • Dec 2015
                                          • 24
                                          • Polska
                                          #40
                                          Hi
                                          Techman1025
                                          thanks
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • lap-top123
                                            Hp elitebook 850 g8 dead after bios flash, need help with rebuild bios file.
                                            by lap-top123
                                            HI, i have hp elitebook 850 g8, that had a mdm lock. i bought new bios from ebay and programmed it and laptop died. Its takeing only 0.035A and blinking diode white and orange, soldering for sure ok . After that laptop is dead, even i flashed back old one bios and still the same. I need unlocked working bios. Please help.
                                            Hp Elitebook 850 G8
                                            ProdID 52W98EC#ABD
                                            SN# 5CG1458XQ7
                                            Mac-address #1: 84:14:4D:2C:4B:5B
                                            UUID: E36E3883-22CF-486D-B7E8-27F88BB0AC90
                                            Mainboard : 6050A3216701-MB-A01(A1)
                                            08-20-2025, 07:28 AM
                                          • bondminer009
                                            Need Bios for Latitude 7650 (No Original / dump bios file)
                                            by bondminer009
                                            Good Evening,
                                            Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                                            Thank You
                                            Salam,
                                            Three
                                            11-12-2024, 07:48 AM
                                          • joshAU
                                            BIOS file for N550JK (original dump attached)
                                            by joshAU
                                            Hi all.
                                            I'm looking for a BIOS file for an Asus N550JK.
                                            I have a Asus R552J, which I believe is identical to the Asus N550JK.
                                            I downloaded the latest BIOS (210) for the R552.
                                            It is named N550JKAS.210.
                                            The BIOS file is however only 6mb in size.
                                            I've read the chip with a CH341A programmer and verified the file.
                                            That file is actually 8mb in size.
                                            I'm wanting to remove the BIOS password from this unit.
                                            It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                                            08-09-2022, 08:06 PM
                                          • adelage
                                            Merge ECS Z77-H2 bios cap file with original dump
                                            by adelage
                                            I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                                            03-11-2025, 03:07 AM
