help change the mac address from the bin bios file
  • bakre
    • Dec 2014
    • 105
    • Zwolle
    hello gays i have an problem in lenovo t430
    i need to change the mac address and the mac address is stored in the bios chip u49 and the size of that chip is 8 mb
    i open the bios file in hex and i search for the old mac and i find a lot of the same mac address and i change all the mac address i find it
    and i programmed the chip and it steel give the old mac address in the setup bios
    did any one have an idea how can i solve this problem
    the laptop mac address is : 00 21 CC D7 9B 43
    thanks a lot
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3636
    • slovakia
    Re: help change the mac address from the bin bios file
    mac can be changed through driver. why u need to change it in bios
    • bakre
      • Dec 2014
      • 105
      • Zwolle
      how i can change it with driver
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3636
        • slovakia
        many tools. check "mac changer", or through properieties of network adapter - configure - adwanced
        • Divendra
          NOR Modifier to change Mac address on a good working Bios file
          by Divendra
          Please some one out there how to use NOR Modifier to change Mac address on a good working Bios file from the old corrupt bios file on PS5 ?. Clear under standing how to.
          05-24-2025, 11:07 AM
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • iZakre
          HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
          by iZakre
          Hello everybody!
          To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
          The thing is that I had installed TeamViewer and could log into the computer...
          02-19-2023, 02:27 PM
        • Citymin
          by Citymin
          S/N : 5RNK9FFT70...
          08-05-2025, 05:12 AM
        • maanee11
          Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
          by maanee11
          Hello Everyone,
          I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
          It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
          In the website, you can only see specs etc.
          I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
          11-08-2025, 04:08 AM
