I have a Toshiba L50-C laptop and would like to see if a new bios file would fix it. I have tried to extract the file from the one on the Toshiba website and then tried to delete the extra bits for the windows bios program in a hex editor but the effect was worse than the original. At least I got a few lights with it but not with the one I modified. Here is my original back up and the Toshiba downloaded and extracted bios.fd file. Many thanks for any help. The toshiba is L50-C (PSKWNA-036002).
Please help with bios for Toshiba L50-C
Re: Please help with bios for Toshiba L50-C
I have a Toshiba L50-C laptop and would like to see if a new bios file would fix it. I have tried to extract the file from the one on the Toshiba website and then tried to delete the extra bits for the windows bios program in a hex editor but the effect was worse than the original. At least I got a few lights with it but not with the one I modified. Here is my original back up and the Toshiba downloaded and extracted bios.fd file. Many thanks for any help. The toshiba is L50-C (PSKWNA-036002).Attached Files -
Hi does any kind person out there know where the bios reset jumper is on my toshiba L5-C-1FQ ....board ref. DA0BLXMB6G0 Rev G
At wits end and would be extremely grateful for any info from someone more knowledgeableComment
Have you find anything?Comment
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by HOHAHi can you help me
I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
IP3_TN16S_MB_V30_20210901A
This is the old BIOS file, it is corrupted​...-
Hello, Could you please help me to find bios files (2mb&4mb) for Toshiba Satellite P55T-A5202? I have already downloaded wrong bios files several times. Every time led behaviours are different....
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
