pls. i need bios for Aser Aspire ES1-523-26S0
  • karim011
    • Nov 2016
    • 122
    • Morocco
    Hi guys. pls i need bios for Aser Aspire ES1-523-26S0
    ID Motherboard : C5W1R LA-D661P Rev: 1.0
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    Re: pls. i need bios for Aser Aspire ES1-523-26S0
    More better, if you post the backup bios..
    try this
    Main+EC, extracted from bios Acersite..
    remember you will loose your DMI, although you post your backup first..
    • karim011
      • Nov 2016
      • 122
      • Morocco
      ok. thks
      • tarum2003
        • Mar 2011
        • 15
        thnk. you
        • technician37
          • Aug 2018
          • 30
          • philippines
          it is compatible to ES1-524?
          • lapfix
            • Mar 2020
            • 2764
            • my workshop
            No
            • jaikumarpeddy@gmail.com
              JCS
              • Sep 2015
              • 12
              • India
              friends,I need ES1- 523 LA-D661p v2.0 bios bin file.
              pls send
              thanks
              • peste
                • 13920
                • ROMANIA
                pls send
                thanks
                post the backup copy of the original laptop bios ...
                • vahidsar62
                  • Dec 2020
                  • tehran
                  Hi guys. pls i need bios for Aser veriton L670G
                  ram DDR2
                  Io IT8720F
                  Q45T-AS V:1.0
                  4mb bios chip
                  • peste
                    • 13920
                    • ROMANIA
                    ram DDR2
                    Io IT8720F
                    Q45T-AS V:1.0
                    4mb bios chip
                    • EbrahimSiami
                      Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                      by EbrahimSiami
                      I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                      **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                      **What I have tried so far:**
                      1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                      07-02-2025, 02:31 PM
                    • macabook
                      by macabook
                      🧩 Initial Issue
                      07-24-2025, 02:17 PM
                    • zarabota
                      Acer Aspire A717-71G - problem BIOS with keyboard
                      by zarabota
                      I am experiencing the following issue with my laptop. I have an Acer Aspire A717-71G with a motherboard model C5MMH/C7MMH LA-E911P Rev. 1A. Unfortunately, the original board stopped working, so I purchased a replacement. The new board is the same model but a different revision (Rev. 1B). From what I understand, this should not cause compatibility problems.
                      However, the replacement board came with a BIOS version intended for the Acer Nitro 5 AN515-51, which causes the keyboard to function incorrectly. I attempted to reflash the BIOS chip using a CH341A programmer...
                      09-03-2025, 01:58 AM
                    • cr4zychriss
                      by cr4zychriss
                      • Rebrand: PC Specialist
                      11-14-2025, 04:04 PM
                    • pirati
                      by pirati
                      10-27-2025, 04:20 PM
