v3-471 bios dump
  • dspok
    • Jan 2014
    • 553
    • Nepal
    v3-471 bios dump
    Please share main and ec BIOS for said model.
    MB is DAZQSAMB6F1 REV. F
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    Re: v3-471 bios dump
    try
    • dspok
      • Jan 2014
      • 553
      • Nepal
      Thanks it worked.
      • Andyservo
        • Jun 2013
        • 152
        • Indonesia
        thanks guys..
        • Zazaku
          • Dec 2014
          • 16
          • Indonesia
          Thanks..
          • kimiarayan48
            • Feb 2019
            • 10
            • iran
            HI I HAVE LAPTOP TRAVEL MATE P243P M-G MAIN PART DAZQSAMB6F1 REV:F SYSTEM START WHIT BIOS V3-471 BUT NO DISPLAY
            ORIGINAT BIOS THIS LAPTOP ATTACHED
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
          • DynaxSC
            Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
            by DynaxSC
            I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
            It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
            I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
            11-06-2022, 05:22 PM
          • TacticalFahrrad
            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
            by TacticalFahrrad
            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
            06-30-2025, 04:09 AM
