sonyvaio PCG-61211M core i3 bios
  • kadi144
    • Aug 2015
    • 690
    • algerie
    hi guys
    l seek a dump for sonyvaio PCG-61211M core i3
    VPCEA1S1E
  • Nightwalker813
    • Mar 2016
    • 19
    • Russian Federation
    Re: sonyvaio PCG-61211M core i3 bios
    Here it is.
    In future - It is easy to find needed dumps if you are know name of board.
    As I know for all models VPCEA1(EA2) it bios is work.
    • kadi144
      • Aug 2015
      • 690
      • algerie
      thanks mr.Nightwalker813
      • kadi144
        • Aug 2015
        • 690
        • algerie
        i will try it and reply
        • kadi144
          • Aug 2015
          • 690
          • algerie
          not working
          the motherboard number is :
          M960_MP_MB
          8layer MBX-224
          REV:1.1
          1p-009CJ01-8011
          • Nightwalker813
            • Mar 2016
            • 19
            Very strange... It BIOS for your platform 100%.
            Try one else.
            • WILHELM
              WILHELM commented
              Editing a comment
              BONJOUR, COMMENT INSTALLER CE BIOS IL y a 2fichiers et je n ai aucune idée du comment mettre mon bios a jour avec ces deux fichiers merci
          • teknikbilisim
            • Jan 2019
            • 10
            • turkey
            Try one else.
            Thx mate
            • DUNC4N
              • 3
              • usa
              Try one else.
              bios is working 100%.
              tried on this device, tested for 2 days without any problems.
              Model : Sony Vaio VPCEA3S1E
              Case Sub Code:PCG-61211M
              Motherboard :MBX-224
              CPU: Intel Core i3-370M
              GPU: AMD Radeon HD 5000
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • DynaxSC
                by DynaxSC
                11-17-2023, 10:56 AM
              • grimacelord
                Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
                by grimacelord
                This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
                Motherboard model number: DA0PAMB46A1 REV: A
                Secondary motherboard model number: 0PAB
                SKU: 685K4UA
                Serial number is: 5CD3223BJP
                Recently reflashed this laptop with latest BIOS and once...
                05-07-2024, 08:06 AM
              • DynaxSC
                Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
                by DynaxSC
                I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
                It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
                I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
                11-06-2022, 05:22 PM
              • vinaypundith
                Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
                by vinaypundith
                I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
                So, I'm looking for a BIOS dump for this machine - a 16MB one....
                08-03-2024, 12:32 PM
