Asus main board : X555ld rev 2.0 & rev 3.3 & rev 3.6 bios
  • sparrow2719
    • Oct 2015
    • 69
    • Indonesia
    #101
    Re: Asus main board : X555ld rev 2.0 & rev 3.3 & rev 3.6 bios
    Originally posted by Vesko356
    Find a matching schematic or boardview at the Schematic sub-section and find out yourself instead of asking here.
    Hint: SPI chip has a board position name U2803 ---> see pin #8.
    U2803. OK got it.
    Thank-you.
    • turker27
      • Feb 2021
      • Türkiye
      #102
      thanks
      • SergAN2
        • Jul 2017
        • 13
        • Russia
        #103
        Hi! ASUS X555LF. Motherboard X555LD rev3.3. I have a broken onboard RAM. Can You create modbios with disabled RAM?
        • yvzasl
          • Feb 2022
          • 16
          • Türkiye
          #104
          Thank you
          • Caplaser
            • Feb 2022
            • 5
            • España
            #105
            My laptop turns off after 15 seconds, shows the Asus logo and even enters the bios if i want, but then turns off. Perhaps it is more likely that it is a failure in the electronics but I wanted to try a new bios just in case the failure comes from there.
            The model is X554LA-XX572T, serial number FAN0CV76621343D.
            The white sticker on the motherboard says X555LAB, and printed in white letters on the board X555LD Rev 3.6.
            I attach the backup of my board
            Thank you!!!
            • FreeDee
              • Apr 2018
              • 6
              • Poland
              #106
              Hey,
              I'm searching for BIOS file to ASUS F555LB
              Board: X555LD REV. 3.3
              Thanks in advance
                • 21417
                Originally posted by FreeDee
                Hey,
                Thanks in advance
                Post the laptop serial number and a picture of the long white barcode sticker on the motherboard
                https://www.badcaps.net/forum/troubl...ore-posting​
                • FreeDee
                  • Apr 2018
                  • 6
                  • Poland
                  #108
                  Here it is. I hope that's correct ones
                  • Vesko356
                    Vesko356 commented
                    Editing a comment
                    You MUST:
                    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
                      Name your thread with make, full model numbers and request
                      Provide a BIOS/EC dump if possible
                      Attach files directly to your post instead of linking to external websites
                      Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 12070
                  #109
                  Hey,
                  Thanks in advance
                  Where is original backup bios file ?
                  • FreeDee
                    • Apr 2018
                    • 6
                    • Poland
                    #110
                    Here it is
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 12070
                      #111
                      Here it is
                      X555LB
                      • FreeDee
                        • Apr 2018
                        • 6
                        • Poland
                        #112
                        X555LB
                        Thanks so much
                        • meda03
                          • Feb 2023
                          • 6
                          • türkiye
                          #113
                          Hello, there is a motherboard labeled Asus X555LNB. The owner installed the wrong bios and the graphics card is not visible. In short, I need X555LNB bios, can you please help me... I tried all the ones on this site and it didn't work...
                          i5 5200U
                          Nvidia GT840M
                          ITE:IT8585E​
                        • meda03
                          • Feb 2023
                          • 6
                          • türkiye
                          #114
                          Hello, there is a motherboard labeled Asus X555LNB. The owner installed the wrong bios and the graphics card is not visible. In short, I need a bios X555LNB, can you please help me... I tried everything on this site and it didn't work...
                          ASUS X555LD REV. 3.3
                          LABEL-X555LNB
                          i5 5200U
                          Nvidia GT840M(N15S-GT-S-A2)
                          ITE:IT8585E​
                            • 21417
                            LABEL-X555LNB
                            i5 5200U
                            ITE:IT8585E​
                            Type the laptop serial number that is on the base cover. Also,post a picture of the long white barcode sticker on the motherboard, like the middle picture in this post https://www.badcaps.net/forum/troubl...90#post3240790
                            • meda03
                              • Feb 2023
                              • 6
                              • türkiye
                              #116
                              LABEL-X555LNB
                              i5 5200U
                              ITE:IT8585E
                              serial number F1N0CV61163305C
                              I installed this and the image came but the ssd keyboard and easy flash were disabled.
                              https://www.badcaps.net/forum/troubl...post1295166​
                                • 21417
                                LABEL-X555LNB
                                i5 5200U
                                ITE:IT8585E
                                Try this bios.If you still can`t see the SSD then install the RST drivers https://www.asus.com/uk/support/faq/1044458/
                                • meda03
                                  • Feb 2023
                                  • 6
                                  • türkiye
                                  #118
                                  I will try. I will share the information... Thank you very much for your interest.
                                  • meda03
                                    • Feb 2023
                                    • 6
                                    • türkiye
                                    #119
                                    I installed the bios you gave me and the screen appeared but the same problem persists. I downloaded the IRST driver and it does not appear on the installation screen...
                                    • meda03
                                      • Feb 2023
                                      • 6
                                      • türkiye
                                      #120
                                      SMDFlea, thank you very much, the bios you gave is working, the socket of my HDD board is broken, thank you.
