Toshiba Satellite a200 PSAF6A-07G01N BIOS
  • hazzaman
    • Oct 2016
    • 24
    Hi Guy's,
    I am after the Bios file for a Toshiba Satellite A200-10G
    Model No. PSAF6A-07G01N
    I believe the details below might help.
    Manufacturer: TOSHIBA
    Model(s): Satellite A200 Satellite A200-10G PSAF6A-07G01N
    Chipset: Intel 2A00 rev 3
    Release Date: 2008-12-08
    BIOS ID: SROSA001.86C.0045.D.0708221145
    Chip Size: 1024k
    It is the Australian Version of the Toshiba Satellite A200.
    If someone can help us out it will be greatly appreciated.
    Hazza
  • boyebaran
    • Sep 2015
    • 249
    • iran
    Re: Toshiba Satellite a200 PSAF6A-07G01N BIOS
    hi
    may i know motherboard part number?
    • hazzaman
      • Oct 2016
      • 24
      Originally posted by boyebaran
      hi
      Hello boyebaran,
      I think it is 1110A2111728
      Thanking You.
      • boyebaran
        • Sep 2015
        • 249
        • iran
        you must find part no in pcb.it is not.
        • hazzaman
          • Oct 2016
          • 24
          I hope one of the picture has it.
          • rievax_60
            • May 2012
            • 897
            • australia
            Have you tried extracting it from the BIOS update file? I have successfully done it in the past although I don't fully understand what I'm doing.
            There is a ROM file inside of an update called sa200(10g)_bios_w250.exe
            I cant seem to upload anything at the moment.
            • rievax_60
              • May 2012
              • 897
              • australia
              It has been zipped with 7-Zip and the extension changed to .ZIP. 7-Zip still opens it.
              • boyebaran
                • Sep 2015
                • 249
                • iran
                http://support.toshiba.com/support/f...name=Satellite
                inter your serial number of laptop to search box and find your lop top support page.
                1-if you need rom file for programming so you can get bios file in support and driver page and extract them.you can see rom file in extract file.
                2- if you need to update bios by windows you can download bios application (depend on your windows) and run exe file.it automatically update your bios.
                • hazzaman
                  • Oct 2016
                  • 24
                  Firstly Thank you to rievax 60 and boyebaran,
                  I have downloaded file thanks.
                  My problem is that once I turn the laptop on, it beeps and tells me that
                  0251 CMOS checksum bad, F1 to use defaults, F2 to enter setup.
                  I can access the BIOS change settings, exit , it will reboot and then lock with a black screen.
                  I have a Toshiba Satellite A200 PSAF6A-07G01N.
                  I have replaced the NEC-TOKIN due to it locking up when charging laptop whilst using it.
                  Also replaced HDD and CMOS battery.
                  Pressing ESC when turning laptop ON shows me that it is checking RAM it seems Ok.
                  So once I turn the laptop on, it beeps and tells me that 0251 CMOS checksum bad, F1 to use defaults, F2 to enter setup.
                  Again I can access the BIOS change settings, exit , it will reboot and then lock with a black screen.
                  Can anyone tell me if I can fix it.
                  I feel it might be a BIOS issue, but cannot boot to anything to reflash.
                  Unless someone tell me if I am doing something wrong
                  Can anyone help.
                  • rievax_60
                    • May 2012
                    • 897
                    • australia
                    So you haven't reprogrammed the BOIS EEPROM memory IC yet? With a programmer.
                    I never know for certain that a problem is caused by corrupted BIOS until I have actually reprogrammed it. You must erase it first.
                    • ala_borbe
                      aka Donald
                      • 1625
                      • Malta
                      try different ram memory
                      Im Back... sort of...
                      • hazzaman
                        • Oct 2016
                        • 24
                        No I have not.
                        Does the 0251 checksum error tell me if it is a corrupt BIOS.
                        I am a noob, I thought I could flash without a programmer.
                        So I need to buy a programmmer, locate the Bios chip, which I believe is under the PCMCIA mechanism, erase then reprogram.
                        Is this correct.
                        • rievax_60
                          • May 2012
                          • 897
                          • australia
                          I dont know what the checksum error means. Is there voltage across the CMOS battery?
                          The EEPROM IC is U33 near the front of the mainboard, 25VF080.
                          Search here for the CH341 programmer.
                          Double check the RAM by using one module at a time in each slot.
                          • hazzaman
                            • Oct 2016
                            • 24
                            Could it be that, because when I press ESC when I power on, it tells me that System RAM Passed.
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              This discussion indicates that the Checksum error can be an error in the BIOS. https://www.cnet.com/forums/discussi...um-bad-290543/
                              • hazzaman
                                • Oct 2016
                                • 24
                                Thanks rievax,
                                I have a new CMOS battery and it is keeping time.
                                Thanks for the info on EEPROM IC being U33,
                                It does the same with one Ram module,(swapped using one at a time). Keeps rebooting when using top RAM slot. Have to use Slot 1.
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  I happen to have an A200 open here, PSAF6A-0SQ01N. It should be comparable to yours. It has ATI HD2400 graphics rather than the HD2600. The BIOS IC is U38 in this model. Check yours.
                                  • hazzaman
                                    • Oct 2016
                                    • 24
                                    I have just opened up and the BIOS IC is U38 and has a red dot.
                                    And I believe is a 25X80VS1G
                                    • hazzaman
                                      • Oct 2016
                                      • 24
                                      Hi Guys,
                                      An update,
                                      Thanks to rievax_60, I replaced my BIOS chip.
                                      I have gone from BIOS v1.5 to BIOS v2.0
                                      Unfortunately it still does the seem thing. I am at a loss to know
                                      what is happening, it boots up, the BIOS system checks the RAM, and it still does the same thing. Goes Black and does not search for the HDD or DVD or Network card.
                                      Does anyone know what can be up.
                                      Could the SATA/DVD controller be faulty and not booting up.
                                      • boyebaran
                                        • Sep 2015
                                        • 249
                                        • iran
                                        please check hdd mode in set up page.(AHCI ,IDE,etc...)
                                          Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 06:10 AM
                                          Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 05:40 AM
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Satellite P50t-C-111 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Satellite P50t-C-111 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite P50t-C-111 boardview and Satellite P50t-C-111 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:10 PM
