dell latitude e4200 PP15S BIOS NEEDED
  • String2016
    • Nov 2015
    • 2235
    • philippines
    Please I need a working bios dump file for this model DELL LATITUDE E4200 PP15S.Laptop turns on but no display. Thanks in advance
  • String2016
    • Nov 2015
    • 2235
    • philippines
    Re: dell latitude e4200 PP15S BIOS NEEDED
    board id:JAZ00 LA-4291P REV.1.0(A00)
    • String2016
      • Nov 2015
      • 2235
      • philippines
      Anyone please help i need good working bios file please help
      • String2016
        • Nov 2015
        • 2235
        • philippines
        Anyone please
        • bachir2004
          • Feb 2015
          • 437
          • maroc
          try this one.
          • String2016
            • Nov 2015
            • 2235
            • philippines
            ok thanks Ill try this
            • String2016
              • Nov 2015
              • 2235
              • philippines
              Still not working laptop turns on then 10sec shuts off ive notice there is no voltage on bios chip bios chip is MxL3205D
              • String2016
                • Nov 2015
                • 2235
                • philippines
                Anyone please help
                • jiroy
                  • Jun 2016
                  • 2416
                  • Lebanon
                  Did you do any usual checks , like removing Battery , resitting memories , remove Hard disk , try another adapter , Etc , Etc ..?
                  • String2016
                    • Nov 2015
                    • 2235
                    • philippines
                    Anyone please help I flashed above bios laptop turns on but 10sec shuts off. original bios laptop turns on but no display I have attached original bios. Can anyone please fix. thanks in advance
                    • cyberhack
                      • Feb 2013
                      • 466
                      • Uk
                      Here i have this and schematics test and report
                      • String2016
                        • Nov 2015
                        • 2235
                        • philippines
                        Ok thanks ill try this
                        • String2016
                          • Nov 2015
                          • 2235
                          • philippines
                          thanks for the response still laptop turns on then 10 sec shuts off no display
                          • String2016
                            • Nov 2015
                            • 2235
                            • philippines
                            Anybody please help
                            • Aarush653
                              Dell Latitude 5340 corrupt bios - clean bios needed
                              by Aarush653
                              Working on a Dell 5340 new Intel 13th gen with a corrupt bios flash.
                              Worked good before failed flash now won't power at all.
                              May have been a bad connection.
                              Want to get a clean rebuild bios like new motherboard so can input Service Tag on bootup.
                              32mb chip - 25Q256JVEN
                              Attach Dell Bios Update file v1.14 - original Dell update...
                              10-14-2024, 04:28 PM
                            • TripTop
                              Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
                              by TripTop
                              Hi
                              i have dell latitude E7270 with following symptoms:
                              - takes long time to restart.
                              - sometimes powers on and then off
                              - sometimes while working it just dies,
                              From googling online bios clean could possible resolve this?
                              i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
                              As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
                              I reinstall...
                              09-09-2024, 02:05 PM
                            • mikeybass
                              by mikeybass
                              04-23-2025, 04:30 PM
                            • Loli Popu
                              DELL LATITUDE 5590 BIOS CORRUPTED BY CH341
                              by Loli Popu
                              Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                              12-13-2024, 08:29 AM
                            • 417731
                              BIOS needed for Dell Vostro 3405
                              by 417731
                              Hi, I have a problem while updating the bios 1.27.0. After that the display went off & the bios states as Dell Inspiron 3505 in the F2 boot > bios > Device when I plug into a secondary monitor. As I don't have any experience in bios, request you to please help me to flash the Vostro bios as they share the common motherboard (GDI53 LA-K037P).
                              Model: Dell Vostro 3405
                              Tag:F0B1YF3
                              CPU:Ryzen 3500U
                              Thanks in advance
                              07-06-2025, 06:48 PM
