Acer E1-572 V5WE2 LA-9532P Rev 1A
    Acer E1-572 .FD bios
    Good Evening
    i have an acer E1-572,(V5WE2...LA-9532P) which starts with a blackscreen, i have tested all voltages are present and laptop functions normal as it should, only black screen, also on external display via hdmi/vga no picture,.
    i have took a backup/dump of bios with ch341A, and then reflashed that dump, no change, downloaded .BIN bios from a site for the same board, flahed with programmer, NO change,
    later saw on different forums that a bios.FD file must be extracted from bios then flashing with USB pen Drive, i dont know how to extract it,.
    will someone spare a few minnutes of their time and extract that file for me, i have attached original bios.DUMP and original from acer website,
    Thanks alot
      Re: Acer E1-572 .FD bios
      2nd file
        here you go
          Originally posted by qayyum786 View Post
          here you go
          Thanks alot, just flashed the bios you gave, with this bios laptop goes on for 1 second goes out, any more idea's.?
          Regards
            here you go
            After cmos reset, laptop now goes on by power btn press and goes out after 2 seconds, then starts again and stays on, with black screen, press and hold power button now wont shuts down the laptop,
            with original bios dump its was going on off with power button,. with this bios not,. so any suggestions, do i need some other bios, or simply the laptop has some fault somewhere...?
              it was extracted from your given .exe file
              send your snid or serial number
                Originally posted by shahnld View Post
                2nd file
                Try..Bios extras din actualizarea site Acer
                DMI 414000-415FFF
                KEYWIN 413000-41303F
                  Good Day.
                  here is the requested info..
                  E1-572-6829
                  SN ID: 40102948234
                  SERIAL: NXM8EAA00840107332A3400
                  Best Regards
                    good day.
                    Here is the requested info..
                    E1-572-6829
                    sn id: 40102948234
                    serial: Nxm8eaa00840107332a3400
                    best regards
                    first from try post #7
                      YES, i am flashing that now, alomost done.. will test in a minute.. thanks
                        Same,. laptop goes on, fan spins a second on 2, fan stops but laptop stays on with black screen,.
                          UPDATE:
                          the problem was with ENE KB9012, Did a reflash to kb9012 and the laptop started to show image. Thanks for all your help and time,.
                            V5We2 la-9532p rev 1a 2013-04-03
                            V5We2 la-9532p rev 1a 2013-04-03 bios needed . dump attached
                              Re: V5We2 la-9532p rev 1a 2013-04-03
                              https://www.alisaler.com/acer-e1-532...ev1a-bios-kbc/
                                Re: Acer E1-572 V5WE2 LA-9532P Rev 1A
                                thanks a lot!!!!!!!!!
                                  thank you
                                    Acer was not displaying anything, this bios reflash worked perfectly thanks.
                                      thank you bro
                                        Thanks a lot, Polytek.
                                          Re: Acer E1-572 V5WE2 LA-9532P Rev 1A biosdunp work 100% i tested
                                          Originally posted by omarzi View Post
                                          hello guys ...
                                          this a Acer E1-572 V5WE2 LA-9532P Rev 1A bios dump i tested it
                                          its working 100%
                                          It works, thank you!
