Acer E1-572 V5WE2 LA-9532P Rev 1A
  • shahnld
    • Nov 2019
    • 159
    • Netherlands
    #41
    Acer E1-572 .FD bios
    Good Evening
    i have an acer E1-572,(V5WE2...LA-9532P) which starts with a blackscreen, i have tested all voltages are present and laptop functions normal as it should, only black screen, also on external display via hdmi/vga no picture,.
    i have took a backup/dump of bios with ch341A, and then reflashed that dump, no change, downloaded .BIN bios from a site for the same board, flahed with programmer, NO change,
    later saw on different forums that a bios.FD file must be extracted from bios then flashing with USB pen Drive, i dont know how to extract it,.
    will someone spare a few minnutes of their time and extract that file for me, i have attached original bios.DUMP and original from acer website,
    Thanks alot
    • shahnld
      • Nov 2019
      • 159
      • Netherlands
      #42
      Re: Acer E1-572 .FD bios
      2nd file
      • qayyum786
        • Aug 2018
        • 1933
        • INDIA
        #43
        here you go
        • shahnld
          • Nov 2019
          • 159
          • Netherlands
          #44
          Originally posted by qayyum786
          here you go
          Thanks alot, just flashed the bios you gave, with this bios laptop goes on for 1 second goes out, any more idea's.?
          Regards
          • shahnld
            • Nov 2019
            • 159
            • Netherlands
            #45
            here you go
            After cmos reset, laptop now goes on by power btn press and goes out after 2 seconds, then starts again and stays on, with black screen, press and hold power button now wont shuts down the laptop,
            with original bios dump its was going on off with power button,. with this bios not,. so any suggestions, do i need some other bios, or simply the laptop has some fault somewhere...?
            • qayyum786
              • Aug 2018
              • 1933
              • INDIA
              #46
              it was extracted from your given .exe file
              send your snid or serial number
              • peste
                • Dec 2016
                • 12792
                • ROMANIA
                #47
                Originally posted by shahnld
                2nd file
                Try..Bios extras din actualizarea site Acer
                DMI 414000-415FFF
                KEYWIN 413000-41303F
                • shahnld
                  • Nov 2019
                  • 159
                  • Netherlands
                  #48
                  Good Day.
                  here is the requested info..
                  E1-572-6829
                  SN ID: 40102948234
                  SERIAL: NXM8EAA00840107332A3400
                  Best Regards
                  • qayyum786
                    • Aug 2018
                    • 1933
                    • INDIA
                    #49
                    good day.
                    Here is the requested info..
                    E1-572-6829
                    sn id: 40102948234
                    serial: Nxm8eaa00840107332a3400
                    best regards
                    first from try post #7
                    • shahnld
                      • Nov 2019
                      • 159
                      • Netherlands
                      #50
                      YES, i am flashing that now, alomost done.. will test in a minute.. thanks
                      • shahnld
                        • Nov 2019
                        • 159
                        • Netherlands
                        #51
                        Same,. laptop goes on, fan spins a second on 2, fan stops but laptop stays on with black screen,.
                        • shahnld
                          • Nov 2019
                          • 159
                          • Netherlands
                          #52
                          UPDATE:
                          the problem was with ENE KB9012, Did a reflash to kb9012 and the laptop started to show image. Thanks for all your help and time,.
                          • jacospama
                            • Aug 2019
                            • 239
                            • Ghana
                            #53
                            V5We2 la-9532p rev 1a 2013-04-03
                            V5We2 la-9532p rev 1a 2013-04-03 bios needed . dump attached
                            • peste
                              • Dec 2016
                              • 12792
                              • ROMANIA
                              #54
                              Re: V5We2 la-9532p rev 1a 2013-04-03
                              https://www.alisaler.com/acer-e1-532...ev1a-bios-kbc/
                              • LevVit
                                • Apr 2019
                                • Украина
                                #55
                                Re: Acer E1-572 V5WE2 LA-9532P Rev 1A
                                thanks a lot!!!!!!!!!
                                • mercur
                                  • Mar 2017
                                  • 6
                                  • algeria
                                  #56
                                  thank you
                                  • pcbuddy247
                                    • Mar 2018
                                    • 4
                                    #57
                                    Acer was not displaying anything, this bios reflash worked perfectly thanks.
                                    • by_mex
                                      • Feb 2014
                                      • 57
                                      • turkey
                                      #58
                                      thank you bro
                                      • fichamba
                                        • Dec 2011
                                        • 131
                                        • Spain
                                        #59
                                        Thanks a lot, Polytek.
                                        • marksik
                                          • Jun 2019
                                          • 27
                                          • Spain
                                          #60
                                          Re: Acer E1-572 V5WE2 LA-9532P Rev 1A biosdunp work 100% i tested
                                          Originally posted by omarzi
                                          hello guys ...
                                          this a Acer E1-572 V5WE2 LA-9532P Rev 1A bios dump i tested it
                                          its working 100%
                                          It works, thank you!
                                            09-06-2024, 05:27 AM
                                            Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                            09-07-2024, 05:00 AM
                                            Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                                            This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 04:10 AM
                                            Acer Nitro Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                                            This specification for the Acer Nitro Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz, Windows 10, Black) boardview and Acer Nitro 5 AN517-54 17.3 inch Gaming Laptop - (Intel Core i7-11800H, 8GB, 512GB SSD, NVIDIA RTX 3060, QHD 165Hz,...
                                            09-07-2024, 03:10 AM
