Need Bios HP ProBook 4331s with ATI Urggent
  • alihomee
    • Dec 2012
    • 1598
    • malaysia
    hi guys i Need Biod HP ProBook 4331s with ATI graphics
    mother bord : 6050A2411501-MB-A02
    this is his orignal with password
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Need Biod HP ProBook 4331s with ATI Urggent
    here you go
    and before all that you might try holding left-right arrows or up-down (dont remember exactly) and turn it on while holding
    sometimes it enters bios and then you do load security defaults and thus clear the password
    if you use this bios
    you will have to use nbdmifit to fix serial and model info
    Im Back... sort of...
    • alihomee
      • Dec 2012
      • 1598
      • malaysia
      thank you very much you are great
      with keys nothing happen but with bios now ok
      can you plz help me about hdd password how to clear
      • alihomee
        • Dec 2012
        • 1598
        • malaysia
        can you plz tell me how to use nbdmifit and how to make usb
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          depends on type and model of hdd
          there are scripts for mhdd but only works on wd, and you can use ttl adapter for seagate hdds
          for others must use PC3000 which is to expensive
          it takes much time and effort but it can be done for free for wd and seagate drives
          Code:
          http://forum.hddguru.com/viewtopic.php?t=12257&start=20
          Code:
          http://forum.hddguru.com/viewtopic.php?t=8374&start=20
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            in this nbdmifit you have windows app
            • studdy05
              Bricked HP Probook 450 G7 Bios questions
              by studdy05
              Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
              Ive got...
              07-08-2025, 09:24 PM
            • macabook
              by macabook
              🧩 Initial Issue
              07-24-2025, 02:17 PM
            • cr4zychriss
              by cr4zychriss
              • Rebrand: PC Specialist
              11-14-2025, 04:04 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
              by Vesko356
              08-11-2023, 03:27 AM
