HP elitebook 840 G3 pass
  • rex98
    • Feb 2023
    • 1281
    • Mandaue CEBU, Philippines
    #261
    Re: HP elitebook 840 G3 pass
    maybe someone need this universal bios for HP Elitebook 840 G3 6050A2892401-MB-A01
    for unlocking without any eror. this bios works without your DMI. no need rebuild, this fixes no display. etc
    if you flash both. its already clean me fast boot.
    kindly give feedback please....
    • JRACH
      • Sep 2023
      • 3
      Elitebook 840 G3 6070B0883401 "Authentication Failed"
      Hi, i got a locked Elitebook 840 G3, unsoldered the IC (winbond 25q128fvpq) flashed it with CH341A and unlocked it with RCunlocker. I successfully soldered it back in, but now i got a "Authentication Failed" error when trying to enter Bios.
      The Board Number is: 6070B0883401 REV: 1.01 A01
      The Laptop SN# is 5CG7242DC8
      Here is the orginal Bios dump as well as the unlocked one:
      • hoaca388
        Badcaps
        • Jan 2022
        • 11891
        #263
        Re: Elitebook 840 G3 6070B0883401 "Authentication Failed"
        Are you restore DMI ?
        • JRACH
          • Sep 2023
          • 3
          Problem solved. The IC was write protected. Unprotecting it with Beoprogrammer helped.
          • niggi
            • May 2016
            • 191
            • UAE
            #265
            kindly remove this bios password 840 g3 , 6050A2892401-MB-A01
              • 21186
              You MUST post the serial number.Havn`t you tried RCUnlocker ?
              You MUST:
              Requests for password removal or BIOS repair for which the method is available at BIOS guides, methods, resources and tools will not be tolerated anymore if you do not explain why you did not succeed.
              • niggi
                • May 2016
                • 191
                • UAE
                #267
                SN#5CG7066KW3
                NO I did not try rc unlocker
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11891
                  #268
                  SN#5CG7066KW3
                  Unlocked
                  • niggi
                    • May 2016
                    • 191
                    • UAE
                    #269
                    [QUOTE=hoaca388;1291013]Unlocked[/
                    its working thank you soo much
                    • nicken88
                      • Sep 2023
                      • Spain
                      #270
                      You saved my laptop. TY!
                      PS: I only needed the first one
                      • douha
                        • Sep 2014
                        • 44
                        • maroc
                        #271
                        Hi freinds pleas help me to unlock this bios
                        And i need to know how to do i try by this way but no result
                        • qayyum786
                          • Aug 2018
                          • 1933
                          • INDIA
                          #272
                          Use RCUnlocker
                          • Zickko10
                            • Sep 2021
                            • 85
                            • Nigeria
                            #273
                            the laptop have bios password
                            here is the info and old bin of the laptop
                            BOARD NO: 6050A2892401-MB-A01
                            S/N:5CG6522P2Y
                            PROD ID:L3C64AV
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11891
                              #274
                              S/N:5CG6522P2Y
                              PROD ID:L3C64AV
                              Unlocked
                              • Zickko10
                                Zickko10 commented
                                Editing a comment
                                The bios has been automatically lock back by itself
                            • Zickko10
                              • Sep 2021
                              • 85
                              • Nigeria
                              #275
                              Originally posted by hoaca388
                              Unlocked
                              It worked but no serial number or sku on it
                              • hoaca388
                                hoaca388 commented
                                Editing a comment
                                See file DMI info
                            • Zickko10
                              • Sep 2021
                              • 85
                              • Nigeria
                              #276
                              Unlocked
                              • rex98
                                • Feb 2023
                                • 1281
                                #277
                                upload the EC chip.
                                • auszylow
                                  • Jul 2023
                                  • 16
                                  • United Kingdom
                                  #278
                                  Hi everyone. Can you help me remove password from my bios , please?
                                  6050A2892401-MB-A01
                                  SN#5CG7361CDN
                                • sc84647
                                  • Mar 2016
                                  Hi
                                  I have an EliteBook 840 G3 that boots with "Machine is not in committed state!​", it looks the system info is correct (serial number, UUID).
                                  How do I put the machine into committed state?
                                  Thanks!
                                  • Vesko356
                                    Vesko356 commented
                                    Editing a comment
                                    Off topic. This thread is about bios password removal.
                                    Use the search engine and post in a related thread about bios repair for this model.
                                    Before that read the posting rules in this sub-section!
                                • mekvit
                                  • Jun 2018
                                  • 39
                                  • nigeria
                                  #280
                                  Hello, i have this HP probook 840 g3 i used unlocker to unlock the bios password, i programmed the unlocked file but the screen dims and fan spins, no display.
                                  Motherboard number: 6050A2892401-MB-A01
                                  Serial number:5CG7131NXC
                                  I uploaded the locked bin file and the unlocked bin file.. THANKS
                                    SMDFlea commented
                                    Editing a comment
                                    Thread merged,no need to start a new thread....
                                • STKR123
                                  The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                  by STKR123
                                  Greetings badcaps community,
                                  I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                  So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                  Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                  I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                  These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                  I learned that desoldering...
                                  10-29-2024, 06:03 AM
                                • macabook
                                  by macabook
                                  🧩 Initial Issue
                                  07-24-2025, 02:17 PM
                                • jotati7062
                                  Hp Elitebook 860 G10 Admin/bios Pass
                                  by jotati7062
                                  Hello guys, I saw your posts of "hoaca388" on this fourm helping others which is very nice of him,
                                  i do have an HP 860 G10 LOCKED, i looked at the bytes he change after an unlock and applied the same on my bios file but i get error that "bios was recovered from EC chip due to data mismatch, do you guys think you can help? if so here is my main bios backup, if i have to backup EC chip, i will, Thank you so much...
                                  08-13-2025, 04:33 AM
                                • Guest
                                  Elitebook 850 G5 BIOS bricked
                                  by Guest
                                  I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                  I assume the BIOS update failed, so I searched for the BIOS chip.
                                  I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                  However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                  Can the corrupted...
                                  03-24-2025, 01:21 AM
                                • Vesko356
                                  by Vesko356
                                  08-11-2023, 03:27 AM
