Hi. I need BIOS dump for HP Pavilion DV6-3120US. I will be very thanksful.
Need BIOS dump for HP Pavilion DV6-3120US
Tags: None
Re: Need BIOS dump for HP Pavilion DV6-3120US
here you go, make backup of old biosAttached Filesif you find these attachements useful please consider making a small donation to the site
Im Back... sort of...
MB: DA0LX8MB6D1 REV: D
IC: WINBOND 25Q16BVSIG
I will try.Comment
Try this.Attached Filesif you find these attachements useful please consider making a small donation to the site
I try with this:
https://drive.google.com/drive/folde...GxRSlRVOWRiOHM
After that notebook turn on but F11 and F12 led are on all the time and CapsLock blink 5 times. By HP error codes it mean motherboard failure.Comment
Reflow didn help and i can not reball or replace it at this moment. Thank you anyway.Comment
by olfelysRequest: Looking for a BIOS dump for HP Pavilion 500-560nf (SKU L1V04EA), motherboard Pegatron Memphis-S / SSID 2B2C.
My board enters jumper recovery mode but no BIOS files are available from HP anymore.
I need the full 8 MB BIOS dump (.bin) (with .sig/.s12 if possible), or at least a clean dump I can flash with CH341A.
Already checked HP support & Win-Raid packages (they only contain Intel ME firmware, not the BIOS).
post moved...next time look for a thread with the name and model, motherboard model of the laptop, and post there, if you can't find it,...-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
by CityminHi all,
S/N : 5RNK9FFT70...-
- Loading...
