samsung np270e5e bios
  • Noreddin
    • Jan 2020
    • 73
    • mostaganem
    #41
    Re: samsung np270e5e bios
    • AdriSC
      • Jul 2021
      • Salta Capital
      #42
      Thank you very much, it worked perfectly for a Samsung NP-270E5E
      Use the CH341A software to program the chip, also use the CH341A programmer. Thanks!!
      • Alassane
        • Oct 2018
        • 65
        • MALI
        #43
        Originally posted by marcin02152
        Try.
        thank you very
        • muradterzi
          • Aug 2017
          • 40
          • Türkiye
          #44
          Originally posted by ridamouh159
          I have 2 dumps for your model
          but the motherboard number is different
          you can try it
          the firts is for BA41-02206A
          thank you
          • pcomp
            • Dec 2020
            • Argentina
            #45
            the 2 second
            Thanks you!
            • teknik143
              • Jul 2020
              • turkey
              #46
              Thank you
              • madamilla
                • Mar 2025
                • Mozambique
                #47
                samsung 270E5G bios
                I have a Samsung mobo BA41-02308A with a burnt SIO and bios chip. I received it from a customer and i am looking for EC and bios dump. Please help me.
                • peste
                  • 13451
                  • ROMANIA
                  #48
                  Originally posted by madamilla
                  samsung 270E5G bios
                  post S/N, full name and model, motherboard model, etc.
                  post the contents of the bios chip even if it is corrupted..
                  • madamilla
                    • Mar 2025
                    • Mozambique
                    #49
                    Thank you for your quick response.
                    The EC and bios chips were completely destroyed hence there was no way of copying the bios file. However, I have solved the issue by copying a dump from a friend's laptop of the same model and i have replaced the chips with new ones.
                    Thank you very much for the response.
                    • amor
                      • Nov 2023
                      • 11
                      • Uganda
                      #50
                      hi i need a bios
                      lampard -15LE rev 1.0
                      it has a nvidia chip
                      notebook hoyt6yk
                        • 21692
                        Originally posted by amor
                        hi i need a bios
                        notebook hoyt6yk
                        Type the laptop serial number, full name and model, motherboard model, etc.
                        read the forum rules..https://www.badcaps.net/forum/troubl...before-posting
                        • Kjell
                          Samsung Series 9 - BIOS issue
                          by Kjell
                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                          08-01-2025, 09:15 AM
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          07-24-2025, 02:17 PM
                        • Habble7
                          by Habble7
                          Suspected Cause:
                          Troubleshooting Attempts:
                          05-22-2025, 07:28 AM
                        • Citymin
                          by Citymin
                          S/N : 5RNK9FFT70...
                          08-05-2025, 05:12 AM
                          by Vesko356
                          08-11-2023, 03:27 AM
