Hp 6460b bios
Re: Hp 6460b bios
the original bios of your laptop, to take the DMI information from there and pass it to the bios you have now ...bios backup..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
Every donation made will go towards server fees and maintenance costs.Comment
Re: Hp 6460b bios
This is what I did,
1- Download the original BIOS dump posted in this thread by imranromi on 11-24-2016, 06:46 AM. File: HP 6460B 6050a2398701 4MB.zip
2- Rename it as BIOS.bin and open with an hex editor; I use Notepad++ with the additional HEX Plugin
3- Jump to memory address containing DMI; S/N at offset 0x00311003
4- Modify manually DMI with your hex editor; S/N, P/N, Asset Tag as per stickers inside your laptop
5- Save as new file BIOS_personalized.bin and clean the ME Region;
See dedicated tutorial -> https://winraid.level1techs.com/t/gu...lization/31277
6- Flash the final BIOS_personalized_cleaned.bin to your laptopComment
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers š,
Iām kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as itās bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.š
š§ Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
š Problem:š
- Device shows āAdministrator Passwordā...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
by greeliddHi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didnāt work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i canāt find a clean BIOS thatās a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...-
- Loading...
