Hp 6460b bios
  • moitoinous
    • Sep 2020
    • 5
    • US
    Re: Hp 6460b bios
    Originally posted by peste
    post the original bios
    The original BIOS was posted by imranromi on 11-24-2016, 06:46 AM
    Message above.
    • peste
      • 13451
      • ROMANIA
      Re: Hp 6460b bios
      Message above.
      the original bios of your laptop, to take the DMI information from there and pass it to the bios you have now ...bios backup..
      • moitoinous
        • Sep 2020
        • 5
        • US
        Re: Hp 6460b bios
        I finally managed to append my own DMI information into the original BIOS backup for ProBook 6460b that is available earlier in this thread and boot the laptop properly.
        This is what I did,
        1- Download the original BIOS dump posted in this thread by imranromi on 11-24-2016, 06:46 AM. File: HP 6460B 6050a2398701 4MB.zip
        2- Rename it as BIOS.bin and open with an hex editor; I use Notepad++ with the additional HEX Plugin
        3- Jump to memory address containing DMI; S/N at offset 0x00311003
        4- Modify manually DMI with your hex editor; S/N, P/N, Asset Tag as per stickers inside your laptop
        5- Save as new file BIOS_personalized.bin and clean the ME Region;
        See dedicated tutorial -> https://winraid.level1techs.com/t/gu...lization/31277
        6- Flash the final BIOS_personalized_cleaned.bin to your laptop
        • mberbouch
          • May 2014
          • 109
          • Morocco
          Re: Hp 6460b bios
          Originally posted by imranromi
          Working bios try this.
          Thanks for the post.
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • haitham sharabati
            by haitham sharabati
            Hello engineers šŸ˜€,
            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.šŸ˜
            šŸ”§ Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            šŸ’€ Problem:šŸ˜…
            - Device shows ā€œAdministrator Passwordā€...
            08-07-2025, 04:54 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • greelidd
            K6604J Vivobook RTX 4070 BIOS Dump Request
            by greelidd
            Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
            Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
            09-01-2025, 06:14 PM
