HP Pavilion Sleekbook 15-b001ee BIOS dump
  • pcnetch
    • Aug 2013
    • 125
    • Sri Lanka
    If you have please share HP Pavilion Sleekbook 15-b001ee BIOS dump . DA0U36MB6D0 REV: D. Thanks
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: HP Pavilion Sleekbook 15-b001ee BIOS dump
    Try whith this dump
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
    • haitham sharabati
      by haitham sharabati
      Hello engineers 😀,
      🔧 Device Info:
      - Model: HP 15-da2007ne
      - Product Number: 8XF55EA#ABV
      - Serial Number: CND0338P0D
      - CPU: Intel Celeron N4000
      💀 Problem:😅
      08-07-2025, 04:54 AM
    • mariusmotea
      Dell XPS 9315 – TPM not detected after BIOS update (dump attached)
      by mariusmotea
      I’m dealing with a firmware issue on a Dell XPS 9315. After PopOS build in firmware update tool found and install the BIOS v1.29.1, the laptop started showing TPM errors on boot:
      • Alert! TPM could not be initialized.
      • Alert! TPM device is not detected.
      Since then, the TPM is completely missing in BIOS and in the OS.
      Here’s what I tried so far:
      • Downgrade is blocked because BIOS 1.29.1 is marked as “critical.”
      • Reflashing the same version does not help.
      • Left the laptop without battery for a week – no effect.
      • Updated to BIOS 1.31.0 – problem
      Today, 02:07 PM
    • Citymin
      by Citymin
      S/N : 5RNK9FFT70...
      08-05-2025, 05:12 AM
