Hi Toshiba L55-b5294 bios dump needed DA0BLIMB6F0 REV:F
    Re: Hi Toshiba L55-b5294 bios dump needed DA0BLIMB6F0 REV:F
    Originally posted by kazia View Post
    my be this your bios, backup and try..
    thanks you
      This dump would work on a L55-B5276, with DA0BLIMB6F0 REV:F board?
        try it, before you make a backup of the original bios, if it doesn't work put the copy here.
          thank you
            thank u
              Working great on a L50-B-1T1 with the same DA0BLIMB6F0 rev F board. Thank you!
                just show toshiba logo without blacklight then display turns off what can it be it is not lcd
                  satellite s55t-b5152 da0blimb6f0 rev f bios
                  satellite s55t-b5152 da0blimb6f0 rev f bios help my please
                    Thank you, test ok.
                      Hi, i have a L55 with no display, not even external displays, everything seems to work fine, the cooler fan turns on and change the speed, usb keyboard dont turn any led, i can turn off with the power button, all the power supply of the motherbaord have the rigth voltage. I flashed the bios but the problem persist, colud be the EC Bios?? is posible to get a dump file? thanks!
                        Ok thankyou
                          thank you
                            thanks it works
