Bios dump toshiba p50-a
  • quic307
    • Jun 2015
    • 255
    • Greece
    Hellooo...
    I need BIOS DUMP for TOSHIBA P50-A. (not TOSHIBA P50-B)
    I have no power on - off and bios voltage OK.
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: Bios dump toshiba p50-a
    Try
    • quic307
      • Jun 2015
      • 255
      • Greece
      Thank you for BIOS.
      I have one more problem now and I want schematic.
      "dycc" do you have it ??
      • ameerrashed6
        • Jul 2016
        • Yemen
        I need BIOS DUMP for TOSHIBA P50-B
        • heraklion
          Adelele
          • greece
          is this ok for satellite p50-a-144 with dual bios?
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • DProf.
            TOSHIBA DYNABOOK T55/AB, PT55ABP-BJA2 BIOS DUMP
            by DProf.
            High great minds, please i need bios dump for this system .or help to REMOVE the PASSWORD in my original dump
            Toshiba Dynabook T55/AB, PT55ABP-BJA2
            MODEL NAME. Satellite L50-D series
            P[ART NO PS57MN-00600R
            Attached is my original bios dump ADMIN. PASSWORD LOCKED. Thank you in advance....
            09-26-2024, 04:30 AM
          • Ziome3eknh
            Please bios dump toshiba dynabook satellite pro c5-e-104
            by Ziome3eknh
            Hello, I need to fix the BIOS dump or some other working one
            Model: Toshiba Dynabook Satellite pro C5-E-104
            SN: 70014063A
            Motherboard: IP3_KN16R_MB_V20_200326A
            Platform intel Core i5 8gen
            Attached dump​...
            04-24-2025, 11:35 AM
          • DynaxSC
            by DynaxSC
            11-17-2023, 10:56 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
