hp probook 6450b need bios
  • fasda1984
    • Mar 2017
    • 16
    • ita
    Thank you, sorry missed upload procedure. Ok zipped, thank you again. I think was damaged bios, very slow when installing ssd and upgrade ram, so updated F.60 bios version from HP but flashing caps lock and no more boot.
    • fasda1984
      • Mar 2017
      • 16
      • ita
      Ok solved, was damaged SPI (u24) desoldered from other MB (same MX) and reflashed , boot and working fine!!
      • Habble7
        by Habble7
        Suspected Cause:
        Troubleshooting Attempts:
        05-22-2025, 07:28 AM
      • studdy05
        Bricked HP Probook 450 G7 Bios questions
        by studdy05
        Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
        Ive got...
        07-08-2025, 09:24 PM
      • DynaxSC
        by DynaxSC
        11-17-2023, 10:56 AM
      • solomost
        need bios dump for HP ProBook 640 G2
        by solomost
        HI I need bios dump for HP ProBook 640 G2 PLZ☺☺
        prblm: black screen caps lock blinking 5 times then fan spening
        CT: PFKCT00WB69310 REV : 1.20
        motherboard : HSB J Mv-6 94v-0 E89382
        03-21-2025, 06:22 AM
      • ktcar214
        Need help for HP ProBook 445R G6 Secure boot key removal from BIOS dump
        by ktcar214
        Hello.
        I tried to add a custom secure boot key (for secure booting Linux) to my bios, but after this, my laptop bricked. After adding secure boot key (via PowerShell) and enabling secure boot my laptop turns on, shows HP logo, and after 5 seconds it turns off and on, and it repeats forever.
        My goal is to either turn off secure boot or remove my custom key from BIOS dump.
        I'll attach my bios dump (version R79_011700) from my bios chip 25b127dsig, my keys (PK/KEK/db), and bios dump from another HP ProBook 445R G6(I found it on this forum. URL: https://www.ba...
        12-07-2021, 08:57 AM
