HP 15-e009tu DA0R62MB6E1 REV:E BIOS
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 350
    • India
    Hi
    Problem is board turns on .No display. Side charging LED is off every time.
    no v-core power.
    I need bios for this board
  • imranromi
    • Jan 2015
    • 1292
    • Pakistan
    Re: HP 15-e009tu DA0R62MB6E1 REV:E BIOS
    Board model : Da0r62mb6e1 bios
    • imranromi
      • Jan 2015
      • 1292
      • Pakistan
      Check bios reply me if ok this bios
      • ravi_1617
        YY Solutions
        • Jan 2012
        • 350
        • India
        Ok i will let u know
        • ravi_1617
          YY Solutions
          • Jan 2012
          • 350
          • India
          Sir Thanks .
          but my bios is also ok ,some power related problem
          Thanks any way
          • sreeni
            • Jun 2014
            • 4
            • India
            Thanks for the post ,my hp 15-e017TX was dead...no power.But from the above post when i reprogrammed my bios, its back to life now.Once again thanks a lot...
            • walid1992
              • May 2016
              • 36
              • tripoly
              thank you
              • ahmarzo
                • Mar 2015
                • 173
                • india
                Thank you sir this bios is working fine
                • Nadeem Amin
                  • 33
                  • pakistan
                  • Kamar
                    • May 2016
                    • 8
                    • india
                    thanks
                    • zenny95
                      • Aug 2017
                      • 28
                      • romania
                      imranromi working bios for rev e
                      • chandrakant
                        • Nov 2017
                        • 39
                        • india
                        thnx sir
                        • fyaagoub
                          • Dec 2016
                          • 269
                          • maroc
                          thanks
                          • hussaka
                            • Jan 2015
                            • 154
                            • italy
                            thank you
                            • baiceanu_stefan
                              • Feb 2015
                              • 41
                              • Romania
                              working bios. Thank you!
                              • DynaxSC
                                by DynaxSC
                                11-17-2023, 10:56 AM
                              • edward card
                                BIOS Request: MSI Raider GE68 HX 14VGG-287US (Board: MS-15M2) - No POST
                                by edward card
                                I'm requesting a working BIOS dump for my MSI laptop, which I plan to provide to a repair technician.
                                Make/Model: MSI Raider GE68 HX 14VGG-287US Board Model: MS-15M2 (Note: I have the serial number ready to be provided to the technician for DMI transfer)
                                Problem Description: The laptop fails to POST. The only sign of life is the GPU fan spinning up after a couple of minutes. The screen remains black.
                                Background / Fault Event: The system was working perfectly. The issue occurred immediately after entering the BIOS advanced menu and exiting with "Discard...
                                10-06-2025, 05:41 AM
                              • cr4zychriss
                                by cr4zychriss
                                • Rebrand: PC Specialist
                                11-14-2025, 04:04 PM
                              • pirati
                                by pirati
                                10-27-2025, 04:20 PM
