Asus X451M bios dump needed
  • salawayon
    • Nov 2012
    • 577
    • philippines
    With X451MA mainboard and No Display problem with this one. Used the one from the support site and it ends up dead..
    Thanks.
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Asus X451M bios dump needed
    do you have backup? post it here
    Im Back... sort of...
    • salawayon
      • Nov 2012
      • 577
      • philippines
      backup attached...
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        try this
        • salawayon
          • Nov 2012
          • 577
          • philippines
          Thank you very much.... it does fixed the unit.
          • ariful18
            • Aug 2016
            • 20
            • Bangladesh
            i need x451ma rev-2.1 bios. Please Help
            • alihomee
              • Dec 2012
              • 1580
              • malaysia
              try this
              • bhcomputadores
                • Jun 2017
                • 24
                • Brazil
                Originally posted by alihomee
                try this
                Work for mi! Thanks a lot!
                • bhcomputadores
                  • Jun 2017
                  • 24
                  • Brazil
                  Works too !!! thx
                  Originally posted by salawayon
                  backup attached...
                  • Andyservo
                    • Jun 2013
                    • 152
                    • Indonesia
                    Thanks for this fix..
                    • whemson
                      • Sep 2017
                      • 3
                      • brasil
                      backup attached...
                      • rein2017
                        • Jun 2017
                        • 35
                        • Philippines
                        try this
                        thanks bro it is working
                        • evovka
                          • Dec 2021
                          • Belarus
                          Help with firmware on it8985E
                          • peste
                            • Dec 2016
                            • 13173
                            • ROMANIA
                            post the backup copy of the original laptop bios
                            • Naufalhaziq
                              • Apr 2022
                              • 8
                              • Malaysia
                              Need your help, u have ec bios for this mb
                              • hardware1
                                • Sep 2021
                                • 2943
                                • N/A
                                Upload your BIOS Backup, your EC Backup here and someone will try to help you. Also write your Device Serial Number and your SIO Chip Number.
                                all donations are welcome,
                                • kodox
                                  Asus ExpertBook B1400CB Bios Dump Needed
                                  by kodox
                                  need original bios dump, original bios has flashed by other technician before me.
                                  attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
                                  unit info:
                                  Model: Asus ExpertBook B1400CBA-0711A1235U
                                  S/N: R6NXNZ006657238
                                  CN: 7F6F
                                  Mainboard Code: B1500CBA R2.1...
                                  08-16-2025, 12:20 PM
                                • DynaxSC
                                  by DynaxSC
                                  06-14-2024, 03:49 PM
                                • DynaxSC
                                  by DynaxSC
                                  11-17-2023, 10:56 AM
                                • jbonavita
                                  by jbonavita
                                  Some issues
                                  Things I tried
                                  04-29-2025, 09:38 PM
                                • TacticalFahrrad
                                  [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                  by TacticalFahrrad
                                  I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                  BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                  I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                  06-30-2025, 04:09 AM
