Toshiba L500 bios file
  • salawayon
    • Nov 2012
    • 578
    • philippines
    Infos:
    LA-4982P
    rev: 1.0
    Thanks...
  • polytek
    • Dec 2013
    • 496
    • TUNISIA
    Re: Toshiba L500 bios file
    this is for toshiba satellite l500-13v;
    motherboard code :compal-la-4982p-kswaaktwaa
    • walid1980
      • Apr 2012
      • tunisie
      thanks
      • nr1
        • Nov 2016
        • TĂĽrkiye
        Thank you
        • khaledmosa99
          • Dec 2014
          • 75
          • egypt
          great work man
          • String2016
            • Nov 2015
            • 2238
            • philippines
            thanks for sharing
            • canali
              • Oct 2014
              • 192
              • turkey
              Thank you
              • redappleguru
                • Oct 2012
                • 27
                • india
                thank you
                • Taipei
                  • Mar 2017
                  • Taiwan
                  Thank you very much
                  • teknikpc
                    technical
                    • 62
                    • TĂĽrkiye
                    thanks
                    • THESMAGD COMPUTER
                      • May 2018
                      • kenya
                      thanks alot
                      • Magnusa2
                        • Jul 2017
                        • 66
                        • India
                        Originally posted by salawayon
                        Infos:
                        LA-4982P
                        rev: 1.0
                        Thanks...
                        • elcaptin_ahmed
                          • Nov 2018
                          • egypt
                          good job
                          • m.sabry2110
                            • Oct 2017
                            • 133
                            • egypt
                            Thank you
                            • elfenne
                              • Mar 2016
                              • 46
                              • maroc
                              thank you
                              • johnxxx.2019
                                • Jul 2019
                                • philippines
                                thanks....
                                • mhamad
                                  • Jun 2017
                                  • 10
                                  • دمشق
                                  Thank you
                                  • prlio
                                    • Oct 2017
                                    • 21
                                    • Cairo
                                    Thank you
                                    • habib_7_7
                                      • Nov 2015
                                      • 14
                                      • pakistan
                                      thanx
                                      • elfenne
                                        • Mar 2016
                                        • 46
                                        • maroc
                                        thank you
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          Hi everyone
                                          09-06-2025, 05:47 PM
                                        • HOHA
                                          BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
                                          by HOHA
                                          Hi can you help me
                                          I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
                                          IP3_TN16S_MB_V30_20210901A
                                          This is the old BIOS file, it is corrupted​...
                                          10-20-2024, 08:22 AM
                                        • nahidmirzayev
                                          Toshiba Satellite P55T-A5202 BIOS file
                                          by nahidmirzayev
                                          Hello, Could you please help me to find bios files (2mb&4mb) for Toshiba Satellite P55T-A5202? I have already downloaded wrong bios files several times. Every time led behaviours are different....
                                          Yesterday, 11:48 PM
                                        • Forest79
                                          by Forest79
                                          07-23-2023, 07:39 AM
