hp dv3000 bios dump file needs
  • rickybucalan
    • May 2013
    • 322
    • philippines
    hello guys i got here hp dv3000 with no display.
    check all coil voltage is fine. so i supposed its bios problem...
  • gcomputers
    • Apr 2013
    • 509
    • Albania
    Re: hp dv3000 bios dump file needs
    http://www.heimafix.com/forum-178-1.html
    look in this site
    • reizal
      • Oct 2014
      • 111
      • aceh
      hp dv3000
      Hidup yang benar2 membosankan.. hek that bak mita peng
      • rickybucalan
        • May 2013
        • 322
        • philippines
        Originally posted by reizal
        hp dv3000
        thanks, but its (.rom file) i need (.bin file) im using bios flasher CH341A.
        • reizal
          • Oct 2014
          • 111
          • aceh
          just rename to bios.bin
          • rickybucalan
            • May 2013
            • 322
            • philippines
            hp dv3000
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3589
              • slovakia
              u dont even need to rename it. just flash it. i have the same flasher
              • rickybucalan
                • May 2013
                • 322
                • philippines
                Got it,but its not same board mine is DIABLO 6050A2215501.
                and i has 1mb bios file.
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  ok, try this
                  Im Back... sort of...
                  • rickybucalan
                    • May 2013
                    • 322
                    • philippines
                    Originally posted by ala_borbe
                    ok, try this
                    tried but i guess it not the right one.
                    • ala_borbe
                      aka Donald
                      • 1625
                      • Malta
                      how about this one?
                      • tawfeek_mokhtar
                        • Aug 2014
                        • 5
                        • egypt
                        thank you
                        • rickybucalan
                          • May 2013
                          • 322
                          • philippines
                          anyone have diagram for this model tnx?
                          • bondminer009
                            Need Bios for Latitude 7650 (No Original / dump bios file)
                            by bondminer009
                            Good Evening,
                            Need help, is there any possible to get the bios file? Because received from my team without any dump file / original bios file
                            Thank You
                            Salam,
                            Three
                            11-12-2024, 07:48 AM
                          • joshAU
                            BIOS file for N550JK (original dump attached)
                            by joshAU
                            Hi all.
                            I'm looking for a BIOS file for an Asus N550JK.
                            I have a Asus R552J, which I believe is identical to the Asus N550JK.
                            I downloaded the latest BIOS (210) for the R552.
                            It is named N550JKAS.210.
                            The BIOS file is however only 6mb in size.
                            I've read the chip with a CH341A programmer and verified the file.
                            That file is actually 8mb in size.
                            I'm wanting to remove the BIOS password from this unit.
                            It prompts you to input the password when turned on, so its sort of behaving like a power on password rather than...
                            08-09-2022, 08:06 PM
                          • adelage
                            Merge ECS Z77-H2 bios cap file with original dump
                            by adelage
                            I am trying to recover an ECS Z77-H2 motherboard, I dumped the original bios with a ch341a programmer, the bios from the manufacturer is a .cap file of smaller size, and it seems that I need to merge this file with other information from the dump, anyone can explain how to do that?
                            03-11-2025, 03:07 AM
                          • silverflea
                            Need Bios MSI B75A G43 Dump File
                            by silverflea
                            Hi. I need dump file bios MSI B75A-G43
                            My bios got corrupted and wont boot, so i need to flash it using Ch341A programmer, but bios file from the official website is to large, so i need bios dump file from working motherboard, or anyone know how to cut the bios size to fit bios chip
                            Thanks!
                            08-09-2022, 01:37 AM
                          • iZakre
                            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
                            by iZakre
                            Hello everybody!
                            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
                            The thing is that I had installed TeamViewer and could log into the computer...
                            02-19-2023, 02:27 PM
