hp g62 bios
  • mariantd
    • Jul 2020
    • 9
    • romania
    Re: hp g62 bios
    I can't add file here says invalid file I left a link to the bios ://whp-hou4.cold.extweb.hp.com/pub/softpaq/sp55001-55500/sp55430.exe
      • 22293
      Re: hp g62 bios
      Here you are .
      • mariantd
        • Jul 2020
        • 9
        • romania
        Re: hp g62 bios
        ok thanks and how do i write these files? with ch341a? or with usb? the laptop doesn't just flash the LED on the power button and that's it
        • mariantd
          • Jul 2020
          • 9
          • romania
          Re: hp g62 bios
          with ch341a, the LED on the start button flashes in the same way and the power LED is off, what can I do for them? do what
            • 22293
            Re: hp g62 bios
            You should flash it with the CH341A, but before you do "make 2 backups" of your bios and post them here in a zip or rar file.Your bios might be repairable,its usually the ME firmware part of the bios that gets corrupted.If it is fixable thats great,it will save you from having to enter all your DMI info if you flash a virgin bios. The software that comes with the CH341A isn`t very good,try AsProgrammer instead its more reliable https://www.badcaps.net/forum/showpo...6&postcount=10
            EDIT: are you desoldering the bios and using an adapter or using a sop8 clip ?
            • mariantd
              • Jul 2020
              • 9
              • romania
              #26
              Re: hp g62 bios
              I used the pliers and grabbed the chip
              • mariantd
                • Jul 2020
                • 9
                • romania
                #27
                Re: hp g62 bios
                I don't know why but the one from you when I write it does the same, I will try later with your program and I will see what result it gives and I will write to you again, thank you very much for your help and if there is more to help me
                  • 22293
                  Re: hp g62 bios
                  You didn`t make a backup ? If the result is the same with the bios i posted then your problem is somewhere else.With the CH341A you have to erase the chip before writing .
                  • mariantd
                    • Jul 2020
                    • 9
                    • romania
                    #29
                    Re: hp g62 bios
                    yes I deleted before I wrote the bios and it started the laptop worked for 10-15 minutes and after it went out and it does the same with the LED on the start button
                    • mariantd
                      • Jul 2020
                      • 9
                      • romania
                      #30
                      Re: hp g62 bios
                      I wrote the bios from you with asprogrammer I mounted the motherboard and now it started and now to see how long it takes I hope it doesn't do the same only now the data has been deleted from the bios with fcc id model etc how could I to write them again? that it gives me an error when I turn it on
                        • 22293
                        Re: hp g62 bios
                        older bios.
                        • mariantd
                          • Jul 2020
                          • 9
                          • romania
                          #32
                          Re: hp g62 bios
                          thank you very much respect !!
                          • gabiz_ro
                            • Mar 2011
                            • 171
                            • Romania
                            #33
                            Re: hp g62 bios
                            Same G62 01439 board.
                            If I remember right some time ago during bios modding I bricked bios.
                            Try to revive with bootable HP bios recovery stick (unfortunately was one old version) after recovery start result was instant death.
                            Charger light off and only blinking power button.
                            I think problem was downgrading EC firmware.
                            Writing back backups of bios and EC bring it to life again.
                            • totomon78
                              • Nov 2020
                              • Philippines
                              #34
                              Re: hp g62 bios
                              g62-110ee DA0AX1MB6F0 ax166
                              no white light in the charge port when plugged in. but blinks orange light on the charge port led when pressing power on switch. any thoughts?
                              • peste
                                • Dec 2016
                                • 13924
                                • ROMANIA
                                #35
                                Re: hp g62 bios
                                bios and EC extracted from the HP website update .. you have two bios chips on the motherboard, make copies of both bios chips before writing it ...
                                • mohamed.abdulkader
                                  • Dec 2018
                                  • 6
                                  • Lebanon
                                  #36
                                  Re: hp g62 bios
                                  mercii
                                  • djharold
                                    • Aug 2015
                                    • 247
                                    • COLOMBIA
                                    #37
                                    Re: hp g62 bios
                                    thanks
                                    • judamex
                                      Active Member
                                      • Jan 2021
                                      • 186
                                      • Mexico
                                      #38
                                      Re: hp g62 bios
                                      Originally posted by malangg
                                      here are 4mb and 512kb..tested working
                                      main rom is a 1kb more large that original.
                                      • yoloyuan
                                        • Jan 2019
                                        • philippines
                                        #39
                                        Re: hp g62 bios
                                        100% tested for me...main bios and ec bios flashing
                                        • Mitech
                                          • Mar 2023
                                          • 5
                                          • Nigeria
                                          #40
                                          Re: hp g62 bios
                                          Thanks it works like magic
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • cr4zychriss
                                            by cr4zychriss
                                            • Rebrand: PC Specialist
                                            11-14-2025, 04:04 PM
                                          • pirati
                                            by pirati
                                            10-27-2025, 04:20 PM
                                          • Vesko356
                                            by Vesko356
                                            08-11-2023, 03:27 AM
                                          • istvanszasz99
                                            Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                                            by istvanszasz99
                                            Product Name: Razer Blade 15 (2022)
                                            Product ID: RZ09-0421
                                            Motherboard: CH580
                                            BIOS Versions I work with: 2.02 & 2.06
                                            Bios File Size: 32,768 KB
                                            Dear Forum Readers!
                                            I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                                            I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                                            The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                                            !!! MY RAZER BLADE...
                                            11-24-2025, 05:52 PM
