Samsung NP300V5A-A0DUK bios
  • Idoneus
    • Jun 2011
    Hi All,
    I've got the above laptop and it seems to be stuck in a bios recovery loop. It will actively search the CD/DVD drive every boot if there's a disc inserted.
    I have searched high and low on the internet, and now my fingers are sore!
    Does anyone have the bios for this laptop?
    Further board info:
    model np300v5a - a0duk
    Board id ba92 08469b
    bios ver 08fi - would need probably 10FI, bios downgrade protection...
    label reads 08FI BA92-08469B 0622
    Many thanks
  • cyberhack
    • Feb 2013
    • 466
    • Uk
    Re: Samsung NP300V5A-A0DUK bios
    You could save the old bios first then try this
    • highpulse
      i hate HP
      • May 2013
      • 1489
      • portugal
      i got the np300e5a if you need
      • Idoneus
        • Jun 2011
        @Cyberhack
        What did you use to dump the rom? I have had to remove SVP PW's from IBM Thinkpads in the past, but have never played with bios dumps....
        The spec comparison of the two boards seems too far apart for success tho:-(.
        @Highpulse - I hate HP too, maybe they are one and the same!
        Have you got that rom handy:-)?
        • cyberhack
          • Feb 2013
          • 466
          • Uk
          Start with this oh and don't forget to tick the box on the right and select the size then hit read
          • Idoneus
            • Jun 2011
            @Cyberhack
            Thanks for a great tool. I have had a play with it on a live system and confirmed that it does do what it says!! Unfortunately the Samsung I'm working on is a non-booter:-(.
            I have researched a way to read an write to the bios chips directly. I'm currently trialling Rayners SPIPGM software with a homemade LPT interface. The initial results are very positive.
            • highpulse
              i hate HP
              • May 2013
              • 1489
              • portugal
              idoneus i had this problem yesterday , and in the end was a configuration on the bios , disable EFI if running on windows 7 , it was always in loop during post due to not finding or start thru the hdd .
              in any case wich is the size of your rom , i got 2 different rom , one with 4MB and another with 8mb , wich one is yours ?
              • highpulse
                i hate HP
                • May 2013
                • 1489
                • portugal
                here it is , its says e5a but its e5c , but work on both
                • Kjell
                  Samsung Series 9 - BIOS issue
                  by Kjell
                  After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                  Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                  08-01-2025, 09:15 AM
                • macabook
                  by macabook
                  🧩 Initial Issue
                  07-24-2025, 02:17 PM
                • Habble7
                  by Habble7
                  Suspected Cause:
                  Troubleshooting Attempts:
                  05-22-2025, 07:28 AM
                • Citymin
                  by Citymin
                  S/N : 5RNK9FFT70...
                  08-05-2025, 05:12 AM
                  by Vesko356
                  08-11-2023, 03:27 AM
